Task Bar
- Re: Task Bar
Task Bar
21-07-2008 7:26 AM
Has anyone noticed that since SP3 has downloaded when right clicking on the task bar the and then on toolbar the address bar is not there any more. M/S said they were forced to remove it for legal reasons .
2 REPLIES 2
Re: Task Bar
21-07-2008 7:46 AM
Re: Task Bar
21-07-2008 10:05 AM
Thanks for for the advice Bob , i did a little checking to on google to , at 1st i could not understand where it had gone , but i also have a Pc on Vista which has the box at the bottom so it,s not a problem , i just thought that other people would also wonder where it had gone and spent a bit of time trying to find out why it had gone from the toolbar .
