TV Remote
- TV Remote
TV Remote
06-05-2014 10:58 PM
I have noticed that my on off button on my remote is taking a long time to switch on and off all the other buttons are fine,should I buy another remote, I have seen them in the shops priced at nine pounds and they work on most models and wondered if they are easy to set up.
4 REPLIES 4
![](/skins/images/BC0367064B8F4B72BE4C6A50E30BB8A1/responsive_peak/images/icon_anonymous_message.png)
Re: TV Remote
06-05-2014 11:11 PM
You could try taking the back of the remote, and then using methylated spirit on a cotton bud, clean up both the contact pad on the back of the button, and the landing area on the circuit board, then let it dry for a few minutes before putting back together.
I've done this on about 9 TV remotes, and similarly on around 7 telephone handsets and mobile phones, and for me it has always worked.
![Wink Wink](/html/@ED8EAB3707DE077FFF94EEBAB958E3C6/images/emoticons/wink.gif)
Alternatively, search on eBay for either the specific model of the remote handset, or just look for "remote" and the TV model number.
I have done this when buying additional remote handsets and they just work straight out of the box without programming.
You will usually find a few variations in the design, just pick one you like.
![Smiley Smiley](/html/@39650D28FE4EA73A5BA77CFD0A477003/images/emoticons/smiley.gif)
Re: TV Remote
06-05-2014 11:15 PM
It is typicaly the press & hold of 2 buttons for a few seconds, then release & wait till it switches the TV off
or locating the codes
see
How to Program a Universal Remote Control : Universal Remote Programming of TV
see
Re: TV Remote
08-05-2014 9:43 AM
Thanks guys I took your advice and took the remote apart and found some sort of sticky substance on that contact ,I think something must have got inside it I cleaned the contact and it is working fine.
Re: TV Remote
08-05-2014 9:50 AM
That's good to know !
![Cool Cool](/html/@852392E900DCC025F17256C42EA8F698/images/emoticons/cool.gif)
