TF Memory Card problem
shutter
Fixes: 67
I have a 32GB TF Memory card.  It has the following stored on it.
Android wallpapers on SD Memory Card    77 items
LOST.DIR                                                       0 items
Music Vids on SD Memory Card                   14 items
.fseventsd                                                         1 item
.Spotlight-V100                                                  2 items
none of which are important, or wanted to be saved any more.
  so... i have tried to........................
Delete all of them
Delete the contents of folders separately
Format the card using two different versions of formatting. (Linux  "Discs"  and also  "USB Stick Formatter
None of these will remove the content... even though they all report a "success" !.
I also tried to install a downloaded .iso file of Linux Mint 20.2 mate ..... to see if "burning" that to the card would destroy the content .... but again,.... despite it saying that the burn was successful... it did not appear on the listing when re-inserted into the USB slot..  (i have a TF card adapter,)
Also tried it in the "official" card reader slot on the laptop. but all is same as reported above.
Any suggestions as to how i can remove the offending stuff, and regain the use of the 32GB memory.
thanks
18 REPLIES 18
billnotben
Re: TF Memory Card problem
Are you sure it's definitely 32GB and not a fake. I always try "Fake Flash Test" on all the memory cards that come my way. It's surprising how many 64GB and 32GB cards are only 4GB, and 4GB cards which are sometimes just 32meg.
It's a tiny program that runs without any installing and is very quick as it does random writes throughout the cards supposed range which it then attempts to read back.
It's destructive to any data on the card and the card will need formatting afterwards.
fakeflashtest
shutter
Fixes: 67
@billnotben  No !   I'm not sure if it's a fake..... I suppose it could be... will use your linky and find out.
EDIT EDIT EDIT....
Unfortunately, it does not run in WINE on Linux mint !... so still none the wiser..  cheers anyway.
RobPN
Fixes: 14
Has the microSD adapter got a lock switch on it?
If so, it may be locked.
shutter
Fixes: 67
@billnotben  Thanks for the heads up on the fake card software.... I did a "kinda" search on google to see if there was a Linux equivalent... and apparently there is... ( called     f3   ) ( which you have to use on the "command line /Terminal screen )
so I followed the instructions on this page ...
https://www.shellhacks.com/check-real-actual-size-usb-flash-drive-sd-card/
and here is the result .
gerry@SAT-PRO-11inch:~$ sudo apt install f3
[sudo] password for gerry:
Reading package lists... Done
Building dependency tree
Reading state information... Done
f3 is already the newest version (7.2-1).
0 to upgrade, 0 to newly install, 0 to remove and 0 not to upgrade.
gerry@SAT-PRO-11inch:~$ lsblk
NAME   MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
sda      8:0    0 465.8G  0 disk
├─sda1   8:1    0   512M  0 part /media/gerry/F046-8847
├─sda2   8:2    0   513M  0 part
├─sda3   8:3    0   513M  0 part /boot/efi
├─sda4   8:4    0     1K  0 part
└─sda5   8:5    0 464.3G  0 part /
sdb      8:16   1  29.5G  0 disk
└─sdb1   8:17   1  29.5G  0 part /media/gerry/9016-4EF8
gerry@SAT-PRO-11inch:~$ sudo f3probe --destructive --time-ops /dev/sdb
F3 probe 7.2
Copyright (C) 2010 Digirati Internet LTDA.
This is free software; see the source for copying conditions.
WARNING: Probing normally takes from a few seconds to 15 minutes, but
         it can take longer. Please be patient.
Bad news: The device `/dev/sdb' is damaged
Device geometry:
             *Usable* size: 0.00 Byte (0 blocks)
            Announced size: 29.51 GB (61896704 blocks)
                    Module: 32.00 GB (2^35 Bytes)
    Approximate cache size: 0.00 Byte (0 blocks), need-reset=no
       Physical block size: 512.00 Byte (2^9 Bytes)
Probe time: 292.7ms
 Operation: total time / count = avg time
      Read: 232.7ms / 2049 = 113us
     Write: 57.0ms / 2049 = 27us
     Reset: 0us / 0 = 0us
going to investigate further..... maybe there is a "fix" for it....
@RobPN no it's not locked
billnotben
Yes I've always found that software (Fake Flash) useful as it's such a quick check. The other well known one checks every byte so on a big one it could take hours.
I suppose you've been trying "quick" format. Is there an option for a full format? Though it would take a long time. Is there anything like windows where in tools you also have "error-checking" check drive for errors and correct.
shutter
Fixes: 67
@billnotben  Yeah, tried all sorts of types of format... including overwrite with zeros  etc etc etc... everything shows "completed"... or "finished"... etc... but always the stuff is still on the card...( and it's readable ! ! ! ) .. so I can copy and paste it to wherever I want.... except.... i don't want  ! ! ! ! ..
the printout says its "damaged"... and doing searches to fix damage sd card in linux does not come up with anything useful.... so looks like it's a "bin job "
Thanks for your input.
cheers
Fixes: 146
Hi @shutter
Is your problem you have 32GB SD card but you only see around 29 GB ?
This is normal, it's to do with the way the operating system calculates the disk size
Manufacturers of these devices use standard metric values to describe disk space e.g. 1000KB = 1MB, 1000MB = 1GB, and so on. Your computer however measures space using binary such that 1024KB = 1MB, 1024MB = 1GB. So, that means your 32GB drive in decimal is now described as 30.5GB drive in binary by the computer.
The second factor is that because the drive is solid state, the controller in the drive sets aside about 7% of the space in order for it to function properly. So remove 7% from our new figure of 30.5GB and you are left with approximately 28GB.
I did find this information with a google search
HTH
Dan.
billnotben
One last thing that has sometimes worked on a card my PC won't read or handle properly is to find a phone that will format it. Usually I end up trying a few phones.
But as your software seems to suggest that card may have some sort of damaged hardware.
Mook
Seasoned Champion
Fixes: 9
@shutter From a terminal try the following:
df
This will produce a list of devices, so find your TF Memory card in the list making a note of it. The remainder of this will assume it to be /dev/sdb1 However, you must verify the correct device and change it in the following commands:
sudo umount /dev/sdb1
sudo mkfs.exfat /dev/sdb1
sudo fsck /dev/sdb1
The fsck command should say there are 0 files meaning the format was successful. Once you've done this pull the card out and reinsert it to have it auto mounted.
shutter
Fixes: 67
@Dan_the_Van  No that is not the problem...
I refer you to my original post.....
Delete all of them
Using the f3 command line / Terminal on my Linux Mint machine.. shows that the card is damaged... therefore cannot be written to, or formatted...
shutter
Fixes: 67
@Mook   Thanks for your input..... the card was actually sdc1... and here it is on the initial insertion.....before carrying out your terminal work.
now showing the results of the terminal work....
And,...... Finally...... ( after re-insertion ............ )
Mook
Seasoned Champion
Fixes: 9
The device must be unmounted first you've not done this.
shutter
Fixes: 67
@Mook   Aha !.... I see an error in my terminal work.....  misread the unmount command..... should have typed in UMOUNT ( small letters)  not  UN******  ! ! !
so give it another go now...
OK... re-done it ..... here is the result
and then i did the f3 command lines again....
shutter
Fixes: 67
@Mook  after doing the umount again... and removing and re-inserting the card still shows the content as originally posted.
will see if I can do a format on my Android Tablet/phone  ( as suggested by @billnotben  )
