Strange graphical glitches on FF35 menu / Win7
- Re: Strange graphical glitches on FF35 menu / Win7
21-01-2015 7:59 PM
Pic is from right-hand side of screen with the 'history' menu, but other options do similar things.
Also tried going back to FF 34, same.
21-01-2015 8:13 PM
The pic is from FF35.
Forum Moderator and Customer
21-01-2015 8:43 PM
Now seems like an issue delivering content from somewhere?
I've not had the tab not working. All else seems fine, though haven't really checked everything. I've only just noticed this menu glitch by chance. (Don't use the menu much.)
22-01-2015 3:35 PM
If you click on anything on the left part of the original menu you're returned to the inital view.
22-01-2015 5:48 PM
Looks a bit odd though, don't you think?
Didn't occur to me to click on the partially visible bit, just looks as though its rendered wrongly.
Thanks for that, all is well
22-01-2015 6:07 PM
Now I selected History and got the same. I agree it's intentional by the little white arrow in the blue box offering the option to go back to where you were.
26-01-2015 2:49 PM
26-01-2015 7:50 PM
Maybe you just have too many tabs open? Not sure what the limit is on FF, or if memory is an issue.
