Strange '403 Forbidden' Issue
- Strange '403 Forbidden' Issue
Wednesday
Hello again, all!
Although I'm no longer with PN, I know that the people here know an awful lot and may have at least a pointer for this problem I've having.
My set up is now as follows: BT Full Fibre through BT Hub 3 with wi-fi. My website is now hosted by Mystic Beasts (and thanks to those here who recommended them to me).
Here's the issue: from just over a week ago, I haven't been able to reach my own website on some browsers (things were OK for the first month or so after migrating the site).
On Windows 7, Firefox accesses just fine and shows a secure connection with a valid certificate from YR1, but Chrome and Vivaldi give me a '403 Forbidden' despite also showing that the connection is secure and cert is OK.
(On Android phone, I don't have Firefox installed, but Chrome and Vivaldi connect OK with the site both via mobile data and wi-fi through the Hub).
This is what I've done to try to diagnose the issue so far:
On the server side, I've tried toggling between 'Enable TLS' and 'Enable TLS with redirect to https:'. No difference.
(I can't see any issue with the .htaccess file; any problem with that would, I would guess, cause the same issue in Firefox).
On my own side, I've cleared cookies and site data in both Chrome and Vivaldi, and have tried Incognito mode in Chrome and Guest mode in Vivaldi. No change.
I've checked DNS on the Hub, which is set to 'Auto'. Again, I assume that this would have caused the same problem with Firefox if that was the issue.
I've cycled the power on the Hub (actually, that was done for me by a power cut after the problem became apparent).
I've toggled Windows Firewall on and off. Firewall settings on the Hub are set for UPnP and DMZ is off (I'm unable to set Access Control without downloading a blasted app!).
There's also a problem which may be adjacent to this one, in that links to my site from other sites which are coded without the 'www.' element in the URL cannot find the site ('Server Not Found').
I suspect that there's something amiss with the configuration of the site/server, but the hosting checklist at Mythical Beasts shows all is OK.
Before I get on to them, I thought that I'd run this past you all here just in case someone has any thoughts on what could be causing the issue.
Apologies for the length of this post, and thanks in advance for any suggestions you may have.
Re: Strange '403 Forbidden' Issue
Wednesday
Thread moved from Everything Else to Tech Help
Wednesday
Ignoring the browser inconsistencies, HTTP 403 errors tend to point to something server side.
Links without the www prefix being broken sounds like a (domain) DNS issue. Do both www.yourdomain.tld and yourdomain.tld resolve in DNS?
From a Windows command line (replacing with your domain of course): -
> nslookup yourdomain.tld
Wednesday
(Forgot to mention; I did flush the DNS cache as well)
This is what I get:
What's been throwing me about all this is that it isn't happening on all browsers and all platforms.
Thursday - last edited Thursday
Is it only Windows 7 that has the problem ? AI (which of course may well be wrong!) suggests
Google Chrome dropped support for Windows 7 long ago. An old version of Chrome cannot negotiate modern TLS handshakes with updated web servers, frequently resulting in connection or access rejections.
Thursday
This is what I get:
This is missing the answer/reply for the second command. Did it succeed and return the same IP addresses as the first command?
@MisterW also raises a good point about Windows 7, what version of Chrome is installed on that machine? There's a chance it simply doesn't have the intermediate certificates/security cipher support that MB require for successful TLS negotiation. If you configure the site to allow connections over plain HTTP and that works, then it certainly points to something to do with HTTPS.
@MisterW ,
The problems are on W7 with those two browsers.
The thing is, everything was OK until about 27/10, by which time I'd been at MB for over a month, and I didn't change anything at the time the problem started (to the best of my recollection).
For the record, I'm running Chrome v109.0.5414.120 and Vivaldi v5.6.2867.62
What you see is what I got, Bob. Firstly with the 'www.' and then without it.
As I replied to @MisterW a moment ago, I didn't have this issue until about a month after transferring the site to MB and made no changes that I can recall around the time the problem started.
I've now tried removing TLS altogether, and both Chrome and Vivaldi - after warning me that I don't have a secure connection - are coming up with the 403 as before, so I've re-instated TLS with redirect for now.
Thursday
well that's a VERY old version of Chrome , I dont currently have Chrome on my Windows machine but AI says the latest Windows version is 158.0.8127.18 (or .19)
You might not have changed anything but MB may well have done on the shared hosting platform.
Any chance you can test with an up to date Windows and Chrome version ?
Thursday
I'm also running an old(-ish) version of Firefox (115.44), but that doesn't have the problem.
I have no means of trying it on any more recent versions of Windows or Chrome.
I'll wait to see if @bobpullen has any further comment and then report the issue to MB.
yesterday
well that's a VERY old version of Chrome...
Almost four years old by my reckoning.
@thejudge wrote:What you see is what I got, Bob. Firstly with the 'www.' and then without it.
The 'without' doesn't show the answer, your screenshot cuts it off. It needs to return a valid IP address similar to the 'with', or you've a DNS problem.
Noit much more I can suggest without knowing the URL/domain in question and having a poke around. Regardless, if you can't upgrade your operating system/software then seeing if MB can offer some isight is probably the next sensible step.
yesterday
"From a Windows command line (replacing with your domain of course): -"
First time I realised I had a DNS registration!
>nslookup <me>.plus.com
Non-authoritative answer:
Address: <My external Plusnet IP>
I assume this alleviates the "Too many emails from your domain" (plus.com) issue?
yesterday
@pvmb - cross-purposes.
The OP's issue pertains to a non-Plusnet domain registration.
Your observation isn't anything new and has little bearing on email delivery. It's simply the way DNS has always been configured for static IP addresses i.e. there's a forward record to map <username>.plus.com to your static IP and a reverse record to map your static IP to <username>.plus.com.
I imagine the original intent was grounded in the heady days when Plusnet customers were much more likely to be doing things like hosting their own services/mail servers etc.
yesterday
There isn't anything to cut off; that was all I got.
I think I know where (part of) the problem may lie, but I'll contact MB on Monday to see what they suggest. I'll post back here in due course.
Thanks for your help this far.
