Static WAN IP - Port Forward Doesn't Work
FIXED- Subscribe to RSS Feed
- Static WAN IP - Port Forward Doesn't Work
18-02-2017 10:03 PM
I purchased a static IP from Plusnet and am currently using a Draytek 130 Modem and an Asus N66U Router running Advanced Tomato 28.0000 MIPSR2-3.4-138 K26 USB AIO-64K.
For some reason I just cannot open or forward any ports. In the Router GUI the ports are forwarded as I have done with many combined router/modems in the past but when I check for opened ports using online services (http://www.canyouseeme.org/ etc) it reports that all the ports I have manually opened and those set by UPnP are closed. Similarly if I telnet my static WAN and an 'open' port from my Router it cannot connect.
Tools such as http://www.canyouseeme.org/ report the same WAN IP as I see reported in the Router (which is the same as the static IP Plusnet says I have) so I don't think there is any double NATing going on.
I'm reasonable sure that when I used the modem/router Plusnet provided the port forwarding was working so presumably there is something with the distinct Modem and Router set up I now have?
Any help much appreciated; I'm a bit stumped!
Fixed! Go to the fix.
Re: Static WAN IP - Port Forward Doesn't Work
18-02-2017 10:10 PM
Have you checked the Plusnet Firewall (link requres login) is off?
18-02-2017 10:12 PM
@Browni I have now! Yes it was was to off.
19-02-2017 12:48 PM
Does your device have a effectively static IP?
19-02-2017 1:01 PM
@jinky32 - Are the devices to which you are port forwarding to actually on at the time of these tests?
And they are of course on the same network? If this is a new router setup then maybe the devices are stagnating on the old network i.e. 192.168.1.X -v- 192.168.0.X. Also if you have a switch on your LAN power cycle it too.
19-02-2017 8:28 PM
Thanks guys. More reading around and it's actually a 'feature' in Advanced Tomato. Disable DHCP for WAN as described here http://samuelpinches.com.au/blab/port-forwarding-and-upnp-on-advanced-tomato-not-working/
