Squid and error 110 Connection timed out
spodlife
Hi!
Is anyone else running Squid to help ease the load on their broadband connection? And then how many have started seeing error "(110) Connection timed out" at lot more than necessary?
Cheers,
Tim.
3 REPLIES 3
MrC
Re: Squid and error 110 Connection timed out
Not seen any similar problems here (he says, touching wood)
Mike
avatastic
I've been running squid on my connection for years and never had a problem with it (aside from ones that have been caused by myself borking the system config)
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
Fixes: 1,491
only issue I have with it is when the cache directory fills up it sometimes fails, aside from that nothing.
