Smart TV keeps losing network connection
rubix1942
I've recently installed the new EE router, but since then my samsung smart tv has kept losing its network connection.  I can get it reconnected but it doesnt last more than a few hours.
I phoned EE up and they sent a new router out, the same thing happens.
They said if it didn't work then they'll send me an older router, but i'm worried i they do i won't get the faster speed.
Could it be slower with an older router?
21 REPLIES 21
PhilipHeyes
Seasoned Champion
Fixes: 26
Re: Smart TV keeps losing network connection
You just discovered the TV was living on the edge of the coverage with the previous router.
I'd keep the new & speedy EE Router and invest a home network suitable for the size and structure of your building.
rubix1942
what would i need to buy to make the new router work?
Is there any reason why things like alexa that are even further away work fine?
@rubix1942
Maybe your question is best asked on the EE community forum? https://community.ee.co.uk/
The alexa might be working fine as it making a 2.4 GHz band connection which works better at distance, where the TV is using a weaker 5GHz band signal.
The EE Hub does have a compatible Wireless option, maybe try enabling that and select that Wireless SSID for the TV.
Failing that, try an internet search with the TV model number detailing your issue might provide you the answer.
rubix1942
Thanks.
This might be a stupid question.
But i now have 2 ee hubs, could i just plug another one in close to the tv and use that just for the tv?
ExForce9
All Star
Fixes: 11
Yes, you probably can if the router's configuration allows it (most do), as you would need to configure the 'extension' unit to behave as a wireless access point instead of acting as a router.  You should be able to Google how to do that, or see if somebody has posted instructions on the EE community site.
@rubix1942
There are some similarities between the Hub two and EE supplied hub
These instructions might help
https://community.plus.net/t5/My-Router/I-have-a-2nd-plus-net-router-how-do-I-put-it-into-bridging-m...
The two Hubs will need a wired connection.
Take a look at EE wireless extenders as the can use the built in mesh the EE Hubs have.
rubix1942
Thanks thats all over my head lol.  Wish I could go back to my old plus net router never had this problem.
@rubix1942
I suggest you go to the EE forum, as ask for help there.
The previously mentioned compatible mode on the EE Hub would be worth looking at.
ExForce9
All Star
Fixes: 11
or you could do the least technical thing (and most reliable), and just run an ethernet cable between the router and TV.
If you got CAT5e flat cable (example on eBay here), that is easy to hide under carpet, etc.
Personally I run standard round CAT5e between the carpets and under the skirting boards.
rubix1942
Thanks.
Could i ask why wouldnt the 2nd one work if i just plugged it in and connected it to the tv with the diferent password?
Fixes: 585
Plugged in where ?
If you're thinking a phone line extension socket, then you can only have one router making the internet connection
@rubix1942
The issue could be down to the age of the Smart TV rather than a weak WiFi signal, it may not work well with new routers; that is why I have suggested trying compatible mode on the Hub
See https://ee.co.uk/help/broadband/manage-use/how-to-set-up-compatible-wifi
Edit: I'm not saying it will work, but it is worth a try.
rubix1942
I see i didnt know you could only run one phone line.
At this rate the easiest thing would be a new tv.
Funny how the older routers work fine.
PhilipHeyes
Seasoned Champion
Fixes: 26
This device is intended to extend the Wi-Fi in the home :
https://www.screwfix.com/p/tp-link-tl-wpa7517-kit-dual-band-av1000-powerline-adaptor-kit/793rn
The TV could be connected via Wi-Fi or via a network cable.
