Smart TV keeps losing network connection
rubix1942
Re: Smart TV keeps losing network connection
I wonder if i could get them to send me an extender.
Wifi Products | Smart Wifi, Hubs & Enhancers | EE
PhilipHeyes
Seasoned Champion
Fixes: 28
EE will send it.
Add it to your EE account as an extra, it looks like they cost about £150.
Fixes: 480
Which would be a waste of money if it’s a compatibility problem. @rubix1942  Try the advice in post #13 before going any further.
ExForce9
All Star
Fixes: 11
That seems an excessive overkill, when reconfiguring the second router would only take maybe three minutes.
Without knowing the exact model of router you have, these are the generalised instructions -
To complete this setup, you must connect a computer directly to your secondary EE router using an Ethernet cable before modifying the settings below.
1. Match the IP range
  • Find your main router's gateway IP address (usually 192.168.1.254).
  • Log into your secondary EE router's admin panel by typing 192.168.1.254 into a web browser.
  • Navigate to the Advanced Settings or Network menu.
  • Change the secondary router's IP address so it is in the same range but does not conflict with the main router (e.g., change it to 192.168.1.200).
2. Disable the DHCP server
  • Locate the DHCP Server settings inside the secondary router's network menu.
  • Switch the DHCP server to Off or Disabled.
  • Save your changes (this prevents the secondary router from assigning competing IP addresses to your devices).
3. Change the operation mode (if applicable)
  • Look for a setting named Routing Mode or NAT.
  • Switch this setting from Gateway or Routing to Bridged or Bridge Mode if the option is available.
  • Note: If your specific firmware version does not show this option, disabling the DHCP server is enough.
4. Connect the hardware
  • Unplug the Ethernet cable from your computer.
  • Connect one end of a long Ethernet cable into a standard LAN port (not the WAN port) on your main router.
  • Connect the other end into a standard LAN port on your secondary EE router.
5. Finalise wireless settings
  • Connect your devices to the secondary EE router's existing Wi-Fi name.
  • Alternatively, log back into its new IP address (192.168.1.200) to change its Wi-Fi name (SSID) and password to match your main router for seamless roaming.
@ExForce9
I would not use an IP Address in the current Hub's DHCP pool, anything between 192.168.1.1 to .63 is outside.
rubix1942
I've tried many things and many phone calls the now the agent thinks i needed some kind of adapter, that plugs into my hub and then another plugs into the tv...he said he had the same issue and this fixed it (apparantly samsung tv's have issues with new tech)  but for the love of me i cant find the piece of paper where i wrote exactly what its called.
I hope someone might know.
I'm sure he said it connected into the ethernet port in the tv if that helps.  I thought he might have said powerline adapter kit???
ExForce9
All Star
Fixes: 11
Was it 'homeplugs' or 'powerline adaptors' ?
