Skype and video picture
Using Skype and everything is fine except for the Video from the other party which no matter who it's from is fuzzy has vertical lines of green and purple. I contacted Skype but their response was advice on how to set up MY webcam (standard response I guess).
So the problem is my computer - I have checked I have up to date drivers for monitor and image device. I can use MSN messenger without this problem. Anyone got any ideas on what the solution might be.
Re: Skype and video picture
I don't use video with Skype so can't help you with this problem.
However I have always found the Skype forums more helpful than their Customer services
Have a read through the Skype video Forum here
I hope that helps.
