Sharing connection & Monitor
- Re: Sharing connection & Monitor
- « Previous
- 1
- 2
- Next »
24-02-2009 5:02 PM
Someone else on these forums tried connecting two routers to the phone line at the time - and then wondered why they had problems!
24-02-2009 5:25 PM
oh ok, i understand now.
I didn't think i was going mad...just yet
I know this is off thread so sorry for stepping out of line but is there a way to make a pc automatically boot into the 'last know good config' everytime?
24-02-2009 5:50 PM
Quote from: dgreen007 is there a way to make a pc automatically boot into the 'last know good config' everytime?
Why would you want to do that? I've never found it to do any good, ever!
06-03-2009 5:37 PM
You're right, it's a stupid idea. I just thought it would be a solution to a problem I have with another pc of mine which simply doesn't boot anymore.
It was working ok on and off but now something has definitely died....
adie:quote
adie:quote
04-04-2009 11:02 PM
If you want to use a router as a switch you should also disable NAT and DHCP in the second router.
With reference to the PC that has died- do you have the original Windows XP install media? There are some troubleshooting and recovery steps you can follow- but we need to know if you have the disc or not.
- « Previous
- 1
- 2
- Next »
