Sending emails by Java coding
- Sending emails by Java coding
28-07-2017 9:41 PM
I have, in the past and using a different ISP, written Java code to successfully send emails. Just to be clear, this was pure Java code executed at the command line.
With Plusnet, however, the code doesn't work.
Can anyone tell me, is the Plusnet email server relay.plus.net?
I'd greatly appreciate anyones help with this.
Thanks,
Ron.
Re: Sending emails by Java coding
28-07-2017 9:58 PM
What error message are you getting?
28-07-2017 11:59 PM
Can't remember the exact address but that does look about right.
Have you created the mailbox first? - If not you'll need to login to the member centre for that.
MAny smtp servers these days are using encryption which makes life a bit harder for the average home programmer but outlook etc will connect flawlessly.
29-07-2017 10:53 AM
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
29-07-2017 8:31 PM
Plusnet doesn't "do" encrypted email.
The Plusnet outgoing email server is relay.plus.net
30-07-2017 3:47 PM
Hi
Thanks for replying.
I've attached a file which gives the output and the Java code. I'd value any opinion you have.
Thanks,
Ron.
30-07-2017 3:56 PM
Hi 7up,
I've posted the code and the output. Any ideas would be welcomes.
Thanks,
Ron
30-07-2017 4:06 PM - edited 30-07-2017 4:07 PM
@ronw - What issue are you actually having as in the debug output you provided I see:
250 qhMl1v0015Anfxa01hMmoE mail accepted for delivery
What are we missing?
30-07-2017 4:20 PM
Hi
Yes, I saw that.
However the email was not received by either recipient. (Both recipients were me, for testing purposes.)
Thanks,
Ron.
30-07-2017 4:26 PM
30-07-2017 4:31 PM
30-07-2017 7:54 PM
@ronw wrote:
Hi 7up,
Thanks,
Ron
Sorry mate I don't do java but do have experience of working with mail servers (I'm working on one myself plus other tcp server stuff).
If the server is accepting your mail its possible that if your target is a yahoo address that its been rejected because it came from PN with a yahoo address and thus their domain keys tech is probably blocking the mail. That or PN aren't sending it out any further than their own servers to prevent being reporting for spamming.
Also be sure to check your spam folders! You'd be surprised just how many people are caught out by that.
Oh yes the PN server does also refuse to deliver mail sometimes if it thinks you're a spammer - eg sending too many test mails. I've had experience of this in the past when my mail servers / clients stopped working and had to make contact with PN to get it resolved.
