Securely trash HDDs before disposal.
VileReynard
Fixes: 20
Re: Securely trash HDDs before disposal.
Quote from: mcgurka
Now, I would imagine because of the inductive way im which Data on HDD's is written, the storage is magnetic, so.. go rip a magnet out of a loudspeaker, power amp it up, and put a huge bassy tune down it.
I remember seeing a magazine article about this. Even a professional degausser isn't up to the job.
Just possibly, you could try someone at CERN, where they use superconductors for their magnets and maybe it would erase your disk if you cycle through a few thousand cycles...
I wouldn't bet on it working, even so Grin
mcgurka
ok. One Word.
Thermite.
Kinda makes it hard to sell em afterwards though.
I'll stick with dban for now unless there are sensible alternatives that might be better.
mcgurka
OK, on a serious note, how about ERD commander, has a util in it called DiskWipe which erases disks to MOD standard I believe.
Scott
Alex
Fixes: 13
Maybe someone should ask the government .. after all they wouldn't be careless with data and must have stringent security ... haaanngg on a minute .. Roll_eyes
chillypenguin
Quote from: Alex
I understand they use TNT.
Chilly
7up
Fixes: 17
Quote from: chillypenguin
Quote from: Alex
Chilly
lol
VileReynard
Fixes: 20
Quote from: Alex
Chilly
Or possibly sent to a "secure store" in Iowa by Pearson Driving Assessments.
7up
Fixes: 17
Thanks for reminding me axis - I was one of the people who took a test in the 3 years worth of data they lost!
Must ring that helpline..
Oldjim
Resting Legend
Fixes: 63
Rather than start a new thread - this caught my eye - securely wipe SD card
http://www.dslreports.com/forum/r19817921-SD-Cards-are-they-really-wipedmaybe-not
petlew
Well...that made interesting reading.
Strat
Fixes: 565
I once saw a program about Forensic Labs that specialise in recovering data from hard drives in criminal cases.
They were recovering data from disks that had been reformatted, overwritten with random data and burnt.
They were recovering from situations you would have thought totally impossible.
It left me wondering if there was any method apart from vaporising the disk that made it unreadable.
petlew
Have to say. That after suggestions in this post that have varied from technical, through brutal mechanical destruction to radical (vaporisation) the answer would appear to be no! Presumably some anorak with a metal detector could find deeply buried HDD's, s'pose you could try chucking them over the side on a cross-channel ferry trip...but then global warming might eventually leave them high and dry (if you believe that particular piece of propaganda)
Rikaitch
What about taking them to PC world? They seem to like wiping hard drives unnecessarily...
Seriously, how about sending them back to the manufacturers. They do a low level format (normally for free) and if you send a whole batch and explain what you're doing with them, I'm sure they'd be happy to help.
Quote from: Strat
The people I had to use in the past were such specialists!
After a failure of a large RAID5 array they managed to recover almost all of the data.
It took one hell of a long time, and cost a large wedge of cash.
Their true specialism is recovering data from physically damaged disks.
If you think about the circumstances that may result in your HDDs being fire damaged, its pretty easy to see that as well as the physical damage, you also have to contend with the loss of the definitions of your arrays.
The main problems are the length of time for such a recovery, and the cost of the same.
Mostly its not really worthwhile going to such lengths, meaning that utilities such as those mentioned in this thread do render the data effectively unrecoverable (if a stranger had no idea what might be on the media, how much time/effort/money would it be worthwhile for them to spend on an off-chance?)
Its pretty hard to hid from the fact that its possible in many cases though, although with the increase of data density its becoming incrementally harder.
