Saved passwords and usernames not recognised
NDT
This problem exists on links that haven't been chnged for years. Have tested about a dozen assorted solutions but nothing found to solve problem. Believe it may be connected to security, still investigating. I was using Duck, Duck Go. until I discovered it was the cause of computer speed deterioration. Now Using Firefox, (Free)AVG and Windows 10. Thanks for any possible solutions other than to upgrade to Windows 11?
2 REPLIES 2
Fixes: 479
Re: Saved passwords and usernames not recognised
Moderator's note:
Thread moved from Broadband to Tech Help
PhilipHeyes
Champion
Fixes: 19
a dozen assorted solutions  Huh
1) try the credentials in different browsers
2) try the password reset option
3) try to open a new a/c
