Safeguard and Google Safesearch
moylan123
Since enabling Safeguard, google safesearch filtering has been enabled and i cannot switch it off.
I have full admin control on the PC in use, and have had Plusnet FFTP for 12 months before enabling safeguard for the specific purpose of blocking a sites categorised as porn and a handful of specific domains.
Is there a way to enable safeguard without giving control of google safesearch to plusnet?
2 REPLIES 2
markhawkin
Champion
Fixes: 22
Re: Safeguard and Google Safesearch
You could try OpenDNS instead of Plusnet Safeguard.
OpenDNS is quite "granular" in blocking categories.
moylan123
@markhawkin cheers. i'll give that a try
