Routing problems with plusnet today?
Vc5JwX8b
It seems my voip connection to voipify.net ( specifically sip-1.rdg.uk.voipsvr.net ) is not usable today ( no connection via plusnet, but will connect fine via giffgaff or PIA VPN so seems likely the problem is at the plusnet end of things )
Also connections to https://www.plus.net fail from at least PIA VPNs uk_manchester server.
Does others have similar issues?
2 REPLIES 2
markhawkin
Champion
Fixes: 22
Re: Routing problems with plusnet today?
I don't think there is a general problem with Plusnet and Voipify.
You can't ping sip-1.rdg.uk.voipsvr.net but that's also true with another connection I tried.
A trace route stops at the same point on both connections (I guess Voipify's hosting provider).
I occasionally get odd call drops with Voipify which I haven't got a known cause for but using the Plusnet connection it's generally fine.
outcast
Aspiring Champion
Fixes: 19
There are no problems reported on VoIPify's Service Status page
