Router + reverse proxy (a question for webmasters and server experts)
- Re: Router + reverse proxy (a question for webmast...
09-06-2021 9:32 AM
I'm having my personal site hosted home, on a RPi 4 server and it's working great. The plusnet router forwards the thhp/s ports to the local RPi. Now, I'd like to host another RPi server with another domain on it, and from my knowledge it can either be done through a reverse proxy server, because the plusnet router forwards ALL http/s requests to a single lan address (ie my current RPi 4).
The question is (because I don't want to have a chain of RPis connected as a reverse proxy + 2 servers), is there a router that has a reverse proxy server in it? Therefore a router that will 'know' to redirect to the proper local server when a certain domain will be typed in the browser's address bar.
Ideally my home network will be made of the ROUTER > RPi SERVER, where on the server will be 2 different working domains, both public and accessible on http/s without having to type extra port numbers (such as domain1.com:1234, domain2.com:1235), but I don't know if such router even exists. Google is either becoming dumber or more advanced to display proper results to my Qs.
Re: Router + reverse proxy (a question for webmasters and server experts)
13-06-2021 11:02 PM
Why use multiple RPis? - Why not just use Apache's built in virtual hosting instead? - That lets you setup multiple hosts / sites with just one instance of apache running to serve them all.
Unless you have a real need for your sites to be on different physical hardware, i'd go with the VH option.
14-06-2021 4:54 AM
