Ring doorbell 3 not linking to WiFi
catrinevans11
Just purchased a ring doorbell 3 which will not connect to the WiFi. I spent 2 hours on the phone to the ring support yesterday; they tried everything they could and suggested I rang plusnet again, who I’d spoken to first and who’d tried to split the WiFi. The device definitely works, it will
connect up my personal hot spot on an iPhone. Ring support looked at the plus net hub router and said they weren’t able to manually add a device, which they can normally do with other routers. Plusnet suggest trying a BT smart hub, orca WiFi extender, both of which will
cost me money. Any ideas or do I just leave plusnet and try a different provider?Huh
6 REPLIES 6
Fixes: 479
Re: Ring doorbell 3 not linking to WiFi
@catrinevans11  Welcome to the forum.
I’m a bit sceptical about the claim that a Smarthub will work but a Hub One won’t. Under the tweeked firmware and garish case you will find a BT Home Hub 5a.
The Smarthub is a better device, having much better WiFi, which could be your problem. It can be used on Plusnet, many of us do, and can be bought for about £20 on an auction site, which is much less than the cancellation charges for moving on.
For setting instructions follow the links in this post https://community.plus.net/t5/My-Router/Using-A-BT-Smarthub-An-Update/m-p/1795292#M24601
Species5618
Been there spent hours messing around with options, but I DID FIND A SOLUTION
set a static IP in the advanced setup of the ring device
IP 192.168.1.200 (fell free to change last bit a little, )
Mask 255.255.255.0
router 192.168.1.254
DNS 8.8.8.8 (this is google DNS not the hub)
the door bell connected  in seconds !!
pjmarsh
Fixes: 24
I had trouble setting up my Ring Doorbell Pro a couple of years ago, and that was with a different router.  I ended up with Rings advanced support team and I ended up doing a factory reset on the doorbell about 3 times if I remember correctly before it would connect.
Fixes: 1,495
Whereas my Ring Doorbell 3 Plus connected straight away and has been solid.
Fixes: 1,495
Moderators Note
This topic has been moved from Fibre to Tech Help
pjmarsh
Fixes: 24
It might have been worth saying that Ring have recently replace my doorbell as the quality went very poor on it.  The replacement connected straight away.
I've also had to factory reset my parents Doorbell 2, which meant connecting it to a Hub Zero, which also connected straight away aswell.
