Problems using CaptchaSecurityImages since PN PHP upgrade
netman
Huh Does anyone know how I can use CaptchaSecurityImages on my sumit forms as they were working before PN PHP upgrade and now they don't.
Where the page should display the security image I just get a red cross. Tried every trick that I know and now have run out of options.
Can anyone help please?
Netman
23 REPLIES 23
Gabe
Re: Problems using CaptchaSecurityImages since PN PHP upgrade
The image is showing. Have you flushed your browser cache?
Gabe
netman
Undecided Hi Gabe
The image is not showing and I have used 2 different kind of browsers i.e. Chrome and IE. No matter what I do the images do not show. The image that you saw was a static image just to make sure that images were not blocked from PHP pages.
Netman
Gabe
Hi Netman,
What I saw was images generated by http://ccgi.netman.plus.com/cgi-bin/security.lib.php. I reloaded the page and got a new picture each time. I still do if I use that url directly, though I see it's now been removed from the page.
Gabe
netman
Huh Hi Gabe
Yes you are right. I was a bit missleading. The image did reload but the PHP security.lib.php  page would not release the numbers and letters. The to the contact page. I therefore tried another PHP page CaptchaSecurityImages.php which I found on the web and it just leaves a red cross still not passing the numbers and letters back. I am not sure what is going on as I tested both pages on my local machine and they seem to work fine. Confused or what???  Crazy
Netman
Gabe
Hi Netman,
How are you passing the variable? I'd expect the security.lib.php script to work with something like:
<?php
session_start();
require_once "security.lib.php";
//Generate random code.
$_SESSION['random'] = generate_random_code(SP_KEY);
//Show picture
get_security_picture($_SESSION['random']);
and then use $_SESSION['random'] in the script that receives your form. Or have I misunderstood the problem?
Gabe
netman
HI Gabe
Thanks for all your help but I am getting nowhere at the moment. It's a same that before PN upgraded to PHP5 all was well with my site but now I'm pulling my hair out. Well, I would if I had any  Cool
Anyway. The contact page is a html page as you know and it refers to the security.lib.php page
Code:
<?php
define('SP_KEY',        '234612ASgBY0985Sfvtr3WDA345w3f35345dfb');
define('SP_CODE_LENGTH','5');
define('SP_CODE_OFFSET','2');
define('SP_QUALITY',    '80');
define('SP_WIDTH',      '60');
define('SP_HEIGTH',    '30');
define('SP_CIRCLES',    '100');
define('SP_FONT',      '10');
define('SP_TEXT_X',    '7');
define('SP_TEXT_Y',    '7');
//generate random code. this code will be displayed at the image
function generate_random_code($key)
    return substr(md5($_SERVER['HTTP_USER_AGENT'] . $key . date("YmdHis")), SP_CODE_OFFSET, SP_CODE_LENGTH);
//generate picture
function get_security_picture($code) {
//set height and width for image font
    ImageFontWidth(SP_FONT);
    ImageFontHeight(SP_FONT);
//create image
    $im = @imagecreate(SP_WIDTH, SP_HEIGTH);
//set image color
    imagecolorallocate($im, 255 , 255, 255);
//set random text color
    $text_color = imagecolorallocate($im, rand(0,100), rand(0,100), rand(0,100));
//create random color circles
    for ($i=1; $i<=SP_CIRCLES; $i++) {
        $randomcolor = imagecolorallocate($im , rand(100,255), rand(100,255), rand(100,255));
        imagefilledellipse($im, rand(0, SP_WIDTH-10), rand(0, SP_HEIGTH-3), rand(20,70), rand(20,70), $randomcolor);
    imagerectangle($im, 0, 0, SP_WIDTH-1, SP_HEIGTH-1, $text_color);
    imagestring($im, SP_FONT, SP_TEXT_X, SP_TEXT_Y, $code, $text_color);
//output image in browser
    header ("Content-type: image/jpeg");
    imagejpeg($im, '', SP_QUALITY);
//destroy current image
    ImageDestroy($im);
get_security_picture(generate_random_code(SP_KEY));
This places an image ib the html page. Somehow I need to get the image contects to the text box called code and then this is posted to my sendmail php page
Code:
<?php
session_save_path('/files/home3/netman/cgi-bin/SESSIONS/');
session_start();
if( isset($_POST['submit'])) {
if( $_SESSION['code'] == $_POST['code'] && !empty($_SESSION['code'] ) ) {
  //if( $_SESSION['code'] == $_POST['code'] && !empty($_SESSION['code'] ) ) {
// Insert you code for processing the form here, e.g emailing the submission, entering it into a database.
////echo 'Thank you. Your message said "'.$_POST['message'].'"';
//--------------------------Set these paramaters--------------------------
// Subject of email sent to you.
$subject = 'You have a message from Netmans Website';
// Your email address. This is where the form information will be sent.
$emailadd = '[email protected]';
$emailaddfrom = 'Netman web feedback form';
// Where to redirect after form is processed.
$url = 'http://www.netman.plus.com/thankyou.html';
// Makes all fields required. If set to '1' no field can not be empty. If set to '0' any or all fields can be empty.
$req = '0';
// --------------------------Do not edit below this line--------------------------
$text = "Message from Netman Web email/feedback form:\n\n";
$space = ' ';
$line = '
foreach ($_POST as $key => $value)
if ($req == '1')
if ($value == '')
{echo "$key is empty";die;}
$j = strlen($key);
if ($j >= 100)
{echo "Name of form element $key cannot be longer than 100 characters";die;}
$j = 20 - $j;
for ($i = 1; $i <= $j; $i++)
{$space .= ' ';}
$value = str_replace('\n', "$line", $value);
$conc = "{$key}:$space{$value}$line";
$text .= $conc;
$space = ' ';
mail($emailadd, $subject, $text, 'From: '.$emailaddfrom.'');
echo '<META HTTP-EQUIV=Refresh CONTENT="0; URL='.$url.'">';
unset($_SESSION['code']);
  } else {
// Insert your code for showing an error message here
//echo "Sorry, you have provided an invalid security code";
  header('Location:http://www.netman.plus.com/whoops.html');
} else {
David_W
This may have nothing to do with it, but if it's a direct paste you have several major typos in your code.......
Shouldn't it be SP_HEIGHT?
netman
Undecided
OK now you've got me...
Arn't they both the same or are my eyes fuzzy from being infornt of the screen too long  Crazy
Oldjim
Resting Legend
Fixes: 63
spelling of height  Shocked
alanrm
Come on Plusnet - this is a problem in PHP implementation & has exactly the same cause as the problems with sessions.
ALL calls to  session_start(); are failing - there is another post describing complicated ways of getting round it. I found a simpler way
which has also solved the problem with showing the captcha image.
If no session id is assigned php automatically assigns a reference when session_start is called BUT the length of this reference
is too long & choking Plusnet's php implementation. Nothing wrong with scripts, nothing wrong on my Win32 or Ubuntu Linux implementations
with PHP5 - it is Plusnet's implementation.
I use PHPFusion so I can't comment directly on your case but the captcha routine there includes a call to session_start();
The solution is to call session_id(); before calling session_start(); & assigning a short id
eg  session_id("sec");
This has worked both for IM scripts which use session_start(); & PHPFusions  new Member registration script which uses
captcha images.
So... look in your script for the call to session_start(); & place session_id("sec");  before it & voila!
netman
Hi ananrm,
Thanks for the info. But alas I have put my website back to it's original state except for the PHP pages having
session_id("sec");
session_start();
at the top and still no security images shows.... I must be going do-lally by now I guess.
Gabe
Quote from: netman
Try
ini_set('session.save_path', '/files/home3/netman/cgi-bin/SESSIONS');
And remove session_id("sec");
Gabe
netman
Hi Gabe
I don't have an issue with the sessions it's the image security I have a problem with.
However I have done as stated and still no change. I am sure the issue lies with PN PHP config  Crazy
alanrm
Hi netman,
Just to emphasize that it IS the session_start() function implementation which is causing the problem - you are viewing the captcha image
as something different but the problem is caused by the session_start function which is used in this script.
I came to  your query because I had problems with this function in an IM script & after reading your query I found that suddenly the captcha image was not appearing in my PN PHPFusion setup. It was therefore no surprise at all to find that the captcha script included a call to the very same function. These are now working again after my amendment.
I don't know why you need to specify a session save path - does your original script do this? The ONLY change I had to make to two different
scripts causing problems was to set a short file length id by calling session_id() before session_start() specifically to address the error
notice being generated by PHP.
Of course, a reference generated automatically by PHP for a session id should not be rejected by PHP & is not by any other implementation that I have come across.
To Gabe I would say-
Try uploading this script to PN & then explain how to solve the error. There should of course be no error message.
<?php
session_start();
Now upload this:-
<?php
session_id("test");
session_start();
You will of course get a white screen but look at your cookies - the PHPSESSIONID has been successfully created  - it failed on the call just to
session_start()
