Problems loading Pages
- Problems loading Pages
14-09-2009 9:06 AM
Regards John
Re: Problems loading Pages
14-09-2009 9:13 AM
14-09-2009 9:14 AM
14-09-2009 9:42 AM
C:\Users\Bobby>ping www.weather.com
Pinging www.weather.com [63.111.74.121] with 32 bytes of data:
Reply from 63.111.74.121: bytes=32 time=124ms TTL=244
Reply from 63.111.74.121: bytes=32 time=120ms TTL=244
Reply from 63.111.74.121: bytes=32 time=122ms TTL=244
Reply from 63.111.74.121: bytes=32 time=121ms TTL=244
Ping statistics for 63.111.74.121:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 120ms, Maximum = 124ms, Average = 121ms
C:\Users\Bobby>tracert www.weather.com
Tracing route to www.weather.com [63.111.74.121]
over a maximum of 30 hops:
1 3 ms 1 ms 2 ms home.gateway [192.168.1.254]
2 29 ms 30 ms 28 ms lo0-plusnet.pcl-ag02.plus.net [195.166.128.39]
3 26 ms 27 ms 27 ms gi1-2-904.pcl-gw02.plus.net [84.92.0.141]
4 31 ms 29 ms 29 ms te2-1.pcl-gw01.plus.net [212.159.1.113]
5 30 ms 30 ms 27 ms xe-1-2-0-0.lon20.ip4.tinet.net [213.200.79.233]
6 98 ms 98 ms 106 ms xe-2-0-0.nyc30.ip4.tinet.net [89.149.187.70]
7 100 ms 98 ms 101 ms GigabitEthernet2-0-3.GW18.NYC4.ALTER.NET [157.13
0.1.149]
8 104 ms 99 ms 100 ms 0.ge-3-0-0.XL3.NYC4.ALTER.NET [152.63.22.226]
9 119 ms 120 ms 117 ms 0.ge-5-2-0.XT1.ATL5.ALTER.NET [152.63.81.5]
10 124 ms 120 ms 126 ms POS6-0.GW10.ATL5.ALTER.NET [152.63.85.165]
11 126 ms 125 ms 127 ms weather-gw.customer.alter.net [157.130.68.158]
12 123 ms 121 ms 124 ms 63.111.74.121
Trace complete.
This suggests the website's up too.
Can you access the site via it's IP address?
14-09-2009 2:08 PM
Also in Outlook express I get the msg Receiving Mail but the system will time out. Although I can successfully upload large files at the same time.
Rebooting perhaps several times the Modem/Router will fix the problem. The problem is usually worce int evenings.
14-09-2009 2:10 PM
Those timeouts appear to be well outside of our network. The responses from Telia are within the expects levels, and it's not until it's outside the Telia link that problems appear to start happening.
It does appear to be a routing issue, but outside of our control.
17-09-2009 8:15 AM
Thanks for the help.
Regards John
17-09-2009 9:15 AM
17-09-2009 11:15 AM
The Modem Router went from 1458 to 1472 & now 1500.
I initaly chose 1472 as some Netgear help pages said this was for PING & I was trying to PING www.weather.com at the time.
My system seems happy if they are the same. Problem is the system could work ok for a while but generaly seemed to be getting more unstable more often.
Since I changed the MTU setting I have not had a problem.
Regards John
17-09-2009 12:23 PM
17-09-2009 1:47 PM
1. LAN, Cable,DSL, Satellite,ISDN, T1, Wireless or other High Speed Connection ... Sets MTU to 1500.
2. Cable, DSL, Satellite, or Wireless Running PPOE....Sets MTU to 1492.
1500 seems to work so I am sticking with that at present.
What else System Mechanic may change I don't Know.
Regards John
