Plusnet new user
Matt_Hirst
Plusnet new user
Just signed up for a new account with plusnet (had it previously but moved away due to a lack of help when I needed it). Anyway wondering about ensuring I have good coverage at home, current issue I have is max speed I can get is around 31meg FTTC and with two daughters streaming movies, IPADs, Iphones etc and my pc we currently have an issue with stuttering etc (can't use a separate router or rather Netgear 7800 wont play nicely with their modem/router).  Have a mix of wired (cat 6) and wireless devices.
I've got a set of homeplugs to handle the wifi around the house (Devolo Magic 2 wifi) just wondering about a better router with QOS or such like to handle all the connections - what would people recommend?  When I was previously with Plusnet my Netgear router handled streaming and everything just fine am just wondering if there is anything newer or better to handle the QOS or will it be just connect the netgear to the plusnet modem when it arrives and go from there.
What routers would you reccomend?
Matt
4 REPLIES 4
Fixes: 118
Re: Plusnet new user
@Matt_Hirst
Don't know if you noticed this during sign-up but you now get a PlusNet HubTwo modem/router. This is basically a BT SmartHub2. I would wait until you're up and running to see how it goes before investing in extra equipment.
Matt_Hirst
Yes I saw that, do you know if it offers QOS on it or not?
Matt
Matt_Hirst
Googled it no it doesn't have QOS.
Fixes: 480
@Matt_Hirst
If you set your Netgear router up as an Access Point then it will work with your Plusnet hub. Connect it to a LAN socket. See  https://kb.netgear.com/24104/How-do-I-change-my-Nighthawk-router-to-AP-mode-after-I-ve-already-run-s...
