Plusnet Protect- McAfee expired
grace13
I have had the message that my McAfee has expired even though I have Unlimited Fibre.
I seen on a previous forum thread to uninstall and reinstall the software but when I follow the link from my original email to download the software it comes back with sytem error.
Can anyone advise on how I can get McAfee sofware back on my computer and be protected? Annoying when its covered with my broadband and it says its expired
Many thanks
1 REPLY 1
MatthewWheeler
Fixes: 463
Re: Plusnet Protect- McAfee expired
Thanks for getting in touch @grace13
I'm sorry to hear that you've been having issues with your Plusnet Protect.
I've checked your account and I can't see anything that would be causing this.
Can you advise the full error you get when to try to download it again?
 Matthew Wheeler
