Plusnet Hub One
- Plusnet Hub One
Re: Plusnet Hub One
24-01-2016 6:57 PM
Re: Plusnet Hub One
24-01-2016 8:16 PM
Quote Hi, I've got a Sagemcom Plusnet Hub One which makes whistle-y/scratch-y/sounds-like-a-hard-drive-working noises >:(. I phoned and was sent a replacement and this one does the very same thing. It's significant enough - even with talk radio on I can hear the router noise!
Please help?
http://community.plus.net/forum/index.php/topic,114585.msg1302207.html#msg1302207
Re: Plusnet Hub One
24-01-2016 10:39 PM
Hello everyone
I see this thread has been going a long while, I recently have subscribed to plusent TV and have been pushed down the plusnet hub one which I wasn't keen on but my other router was not compatible with Youview.
I have totally fallen out with this router, no remote access am I correct ?
Any way the real gripe I have is port forwarding on this router I've never has so much trouble in life with a router say port conflict with a device you have just chosen er excuse me I've just hard reset your router to make sure there are no devices or port forward rules setup. But it still maintains I have set 1 up. There is no logic to it at all I've managed to setup loads of port forward rules then tried to add 1 more and its says conflict , conflict ? conflict with what I've made a list and I've not used that port before so what gives ? so I then delete that rule I tried to setup and then its says there is still a conflict er hello I've just deleted the 1 you said conflicted.
Please can someone else agree with me or help me out of this or recommend a router that will work with plusnet TV that behaves normally with port forwarding rules.
many thanks hopefully
Re: Plusnet Hub One
25-01-2016 1:25 AM
Re: Plusnet Hub One
25-01-2016 8:48 AM
Wouldn't I still get errors saying port forward conflicts? Or are you saying use my old router to do the port forwarding?
I rather a more permanent solution with a decent replacement I think
dick:quote
Re: Plusnet Hub One
25-01-2016 10:54 AM
Then use the old router to do the port forwarding.
It would only involve swapping a couple of cables to see if its a viable solution.
Disable DHCP on the old router.
Re: Plusnet Hub One
25-01-2016 8:55 PM
Re: Plusnet Hub One
27-01-2016 2:23 PM
Has anyone used a Plusnet Hub One as a bridge to an existing router?
I already have an Asus DSL-N55U which we'd like to carry-on using, because:
1) it can split the Wifi access into seperate Guest and Residents networks
2) we already have a lot of DHCP rules setup for specific MAC addresses
3) remote access routing
4) she-who-must-be-obeyed likes the time-based Parental Controls we have on all our children's computers, tablets, phones, etc
Any config notes would be much appreciated!
Thanks in advance
Re: Plusnet Hub One
27-01-2016 3:40 PM
Re: Plusnet Hub One
27-01-2016 4:41 PM
"change the IP address range on one of the routers"
Is that all? Sounds much too easy!
Re: Plusnet Hub One
27-01-2016 5:04 PM
If you like the way the Asus does things, upgrading to a VDSL Asus may be a good solution for you.
Re: Plusnet Hub One
27-01-2016 6:04 PM
Re: Plusnet Hub One
27-01-2016 7:16 PM
Re: Plusnet Hub One
27-01-2016 8:53 PM
Re: Plusnet Hub One
02-02-2016 9:08 AM
Anyone else find this?
