Plusnet Hub One
anniesboy
Plusnet Hub One
215 REPLIES 215
Chris
Legend
Fixes: 169
Re: Plusnet Hub One
It is indeed an all-in-one Fibre modem/router. Only launched earlier today.
w23
Fixes: 4
Re: Plusnet Hub One
Any technical details available (for those interested)?
Call me 'w23'
DamBuilder
Re: Plusnet Hub One
Looks like it's a re-badged HH5..?
Fixes: 580
Re: Plusnet Hub One
Does look a bit HH5 ish, doesn't it...
w23
Fixes: 4
Re: Plusnet Hub One
Shape and accessories seem to match but then, would it be a 5A or 5B (or random mix of both)?
Call me 'w23'
VileReynard
Fixes: 20
Re: Plusnet Hub One
I wonder if its a crippled HH5 - or not.
Plusnet don't have a good record on "own brand" routers.
anniesboy
Re: Plusnet Hub One
So self install possible?
Chris
Legend
Fixes: 169
Re: Plusnet Hub One
It's a 4 port (all Gigabit) VDSL router, with a/n/ac wireless. It'll be sent to new customers signing up to fibre from today and will mean an engineer is not sent as part of the fibre install.
chenks76
All Star
Fixes: 12
Re: Plusnet Hub One
so by default it's now a self-install FTTC product ?
is one of the gigabit LAN ports used to connect to the master socket? or does it have a separate DSL socket?
Chris
Legend
Fixes: 169
Re: Plusnet Hub One
For new customers yes, upgrades at the moment still require an engineer and will receive the Hub Zero.
chenks76
All Star
Fixes: 12
Re: Plusnet Hub One
why the difference?
Chris
Legend
Fixes: 169
Re: Plusnet Hub One
It's simply the way we've decided to develop these changes.
chenks76
All Star
Fixes: 12
Re: Plusnet Hub One
so, as usual, existing customers get brushed under the carpet in favour of the chase for new customers.
seeing as you're giving away free internet these days, maybe you should remember the customers who are actually paying you for internet. remember those idiots?
Chris
Legend
Fixes: 169
Re: Plusnet Hub One
Sorry that you're not happy but that's the decision that's been made. I'm hopeful that it won't be too long before existing customers get this too.
