Photograph transfer problem
- Re: Photograph transfer problem
02-02-2014 3:55 PM
The reason I wish to do this is fairly detailed and not really relevant to the above.
All the images are jpegs and clearly transfer to the CF card from the computer.
Anyone any ideas ?
02-02-2014 4:29 PM
Also, when you "manipulate" a pic on external progs, you change the characteristics of it... e.g. if you only "improve" the contrast slightly you will reduce the size of the file... so this may well be seen as "corruption" by the camera when it is returned to the camera, therefore it "plays safe"... and says "no image"...
02-02-2014 4:40 PM
02-02-2014 4:49 PM
My wife has a Canon IXUS which takes a sd card, I had no trouble changing the photos and downloading them back to card and the camera could read them, however my own Canon SLR uses a compact flash card but no way can the camera see the downloaded photos, as stated in the article some cameras may not be able to see photos downloaded on a card.
I Did try downloading my photos to the SD card in the hope my wife's camera could see them but no luck.
02-02-2014 4:55 PM
02-02-2014 5:06 PM
York.
02-02-2014 5:06 PM
original pic file name.... (e.g) img00001 downloaded and "fixed" by you, now becomes 001.jpg try changing the file name back to img0001 ( before saving it to the flash card ) ... and see if the camera accepts it....
03-02-2014 8:25 AM
Start > Control Panel > Hardware & Sounds > Autoplay > Pictures ....... drop down menu.... select "Open Folders to view".. you should see the pic files on the card with the camera number as the file name.... Save all the original pics in a NEW FOLDER on your desktop ...... then erase those on the card...... do your "adjustments" and "Save As... " in a sub- folder ( on desktop ? ? ? ) then when finished, you should be able to copy the new ones back to the camera, without changing the file name.... and should be able to read them on the camera... ( hopefully ! ) ..
03-02-2014 11:31 AM
04-02-2014 9:23 AM
For example, the image may have different X Y dimensions or dpi resolution, use a slightly different set of compression table rules, format numeric values in a perculiar way, or have the embedded JPEG thumbnail with a different offset. Sometimes there is no Exif data at all, just a JFIF marker! Meanwhile, your computer/tablet/TV when displaying a JPEG image is doing a load of 'what-if-then-do-something-else' processes. As no one JPEG image is formatted exactly the same as the other, to display custom images inside a digital camera, you need a custom image that has an identical digital signature to a photo taken by the camera.
Try setting the width and height to match those taken by the camera. You might get lucky.
Quote Saving an image file will fundimentally change the digital metadata even though the image remains the same. Here, the first few bytes of an image changes when a photo is imported into a photo editor and is then saved again. Often the image processor in the camera lacks the skill to decode the metadata in the new format.
Camera file:
- ÿØÿà..JFIF.¢...(...........1.......ª...2.......Æ...............i‡.....Ü...¸...Canon.Canon EOS
20D.2012:02:0516:38:10.2012:02:0516:38:10.*è......;ë..............#..........................
................-â†éŠ[Åi±×.^1UÔÀ.ŠÒ¢H......................................................
..........hô÷T.LÊ............................................................................
Post Photoshop save file:
ÿØÿà..JFIF.....H.H..ÿâ.0ICC_PROFILE......0ADBE....mntrRGB XYZ..........acspAPPL....none........
...Ó-ADBE................................................cprt...ü...2desc...0...kwtpt...œ....bk
..Ô....bTRC...ä....rXYZ...ô....gXYZ........bXYZ........text....Copyright 1999 Adobe Systems Inc
orporated...desc........Adobe RGB (1998)..............Photoshop 3.0.....%.........t..«ÁÅW«o….ªø
04-02-2014 10:23 AM
04-02-2014 12:24 PM
The idea was to download the altered photographs to the camera and using the appropriate connector transfer these photos to a first generation ipad.
Now I have already done this with my wife's camera without any problems it's the ones I have took on a Canon SLR that are proving to be the headache, it seems the ipad does not have enough power to transfer the photos direct from a card but if connected to the camera it uses the cameras power.
I Have also tried a usb stick but get some odd message on the ipad there is not enough power to use the device. I am now wondering if the usb stick would work through a powered hub ?
04-02-2014 1:09 PM
Take a couple of pics on an empty card,.... doesn`t matter what... then follow my Start>control panel> instructions and see if that works....
04-02-2014 4:05 PM
http://www.ebay.co.uk/itm/5in-1-USB-SD-TF-Card-Reader-Adapter-Camera-Connection-Kit-for-iPad1-ipad2-...
04-02-2014 5:26 PM
THERE MUST BE A FOLDER TITLED 'DCIM' IN THE ROOT DIRECTORY OF THE SD CARD OR USB. MOST CAMERAS CREATE ONE AUTOMATICALLY, BUT IF YOU CAMERA DOESNT YOU MUST CREATE ONE ON YOUR CARD FIRST.
If your camera numbers are DCIM 000001 ( for example) they must be returned to the camera with that "type" of number in the "root directory"... then it should be able to read them ok....
