PORT open to HNS-WAN-ACCESS
Rich_b
Port 7547 is reachable and is vulnerable from HNS-WAN-ACCESS.
My router is a Plusnet Sagemcom  Model No.  2705N.
I have a query that Avast has thrown up on my Asus laptop.
My question is this important and how can stop and possible set port 7547 Closed?
I have had a quick look at my router's settings but can't see how to do anything to change this situation.
2 REPLIES 2
Fixes: 479
Re: PORT open to HNS-WAN-ACCESS
@Rich_b  Welcome to the forum.
This is an old chestnut, see https://community.plus.net/t5/My-Router/Anti-virus-claiming-router-is-vulnerable/m-p/1553442#M7057
I have checked mine using the GRC Shields Up! port scanner and it comes back as  stealthed.
Rich_b
Thanks, Baldrick1.
I check out GRC shields Up which had used a few years ago but I could not remember their name, so thanks for that.
Shields Up say all well and good.
I apologize for my delay in replying, I could not find my way to here until today.
As I only come across Avast on Window Home 10 now and again it was not much of a problem.
Mainly only use Linux since 2009 so no antivirus software.
