PC to TV
- PC to TV
PC to TV
30-05-2015 11:54 AM
TV is connected to Router via Homeplugs with the new Fast PN router
so how do i set it up to stream to TV or is this not possible ?
Re: PC to TV
30-05-2015 5:21 PM
Re: PC to TV
30-05-2015 5:24 PM
https://plex.tv/
Re: PC to TV
30-05-2015 8:34 PM
Similar to DRM excuse of turning of audio loopback input by default even when the hardware supported it; I forget when they introduced that, maybe with Vista??? In that case it was straightforward to turn it back on again; maybe there is something hidden to re-allow streaming.
Re: PC to TV
30-05-2015 10:51 PM
vilefoxdemonofdoom , the only change is the OS win 10 tell me its not compatible , and it is the ONLY thing it happens to , every other program is ok
Re: PC to TV
31-05-2015 1:22 AM
Re: PC to TV
31-05-2015 8:07 AM
avatastic yes have tried that , am going to try PLEX
Re: PC to TV
31-05-2015 8:29 AM
Re: PC to TV
31-05-2015 3:36 PM
Quote from: rongtw vilefoxdemonofdoom , the only change is the OS win 10 tell me its not compatible , and it is the ONLY thing it happens to , every other program is ok
It would seem foolish to run beta software on a system that is important to you.
I always delay a few months after the official release date so that the more serious flaws can be discovered and fixed.
You have been relatively lucky - so far...
Re: PC to TV
31-05-2015 5:50 PM
Plus i still have my win 7 disc and would only take a few hours to format and reinstall back to win 7
