PC does not recognise UBS connections
- Re: PC does not recognise UBS connections
- « Previous
- 1
- 2
- Next »
11-02-2008 10:33 PM
12-02-2008 12:26 AM
Rourhefamily - the questions which have been asked about where you are plugging in are very relevant - some front panel connections on PC's are actually just a built in hub. As petlew has said, hubs often give problems, and as Denzil says, try back ports to see if they work. Your comment about the Canon suggests the PC has detected and is trying to communicate with the USB device, but failing - this is typical of the sort of problems you see with some USB hubs.
12-02-2008 8:12 AM
Nice to have the luxury of 4 cables to try. However in the past I've used what appear to be identical standard looking cables; one from a Fuji camera and another for a Canon camera, but they would not interchange and had to be used with their respective cameras. My current Pentax camera seems to be happy with any cable used with it. Never did work out which was the non-standard cable, but I suspect it was the Canon. The only slight difference was that the Canon was not purchased in this country (and came without English language software, and wasn't available as a download which Canon were very reluctant to supply)...if that should make any difference?
Quite agree about Canon software which seems to demand to be installed first to avoid problems (this seems to apply across their product range) However it's probably good practice to always install software first anyway.
01-03-2008 3:13 PM
Hi Folks.
Thanks for all the help.
Got the MP3 working.
Will reload Canon Software to try to fix that one
![Smiley Smiley](/html/@39650D28FE4EA73A5BA77CFD0A477003/images/emoticons/smiley.gif)
01-03-2008 3:27 PM
Hey! rourkefamily, you can't leave us in the lurch like that...how did you fix it?
- « Previous
- 1
- 2
- Next »
