PAP2 hardware setup
DickB
PAP2 hardware setup
I have a Linksys PAP2-NA adapter which works fine on outgoing pstn calls, but I'm getting one way transmission on incoming calls.
Any ideas?
puddy
Re: PAP2 hardware setup
                                Line One Info Basic setup
Line Enable:  yes
sip port :5060
proxy :sip2.plus.net                  Register: Yes
Make Call Without Reg: No      Register Expires: 3600
Ans Call Without Reg  :  No
Display Name: sip  id number    User ID: sip id number
Password: sip password          Use Auth ID: Yes
Auth ID: sip id number
                                  Audio Configuration
Preferred Codec:G7LLu            Silence Supp Enable: no
Use Pref Codec Only:No          FAX CED Detect Enable:No
DTMF Tx Method: INFO
DickB
Thanks Puddy
I've checked and all the settings were as you said except the fax ced dectect. I changed that but still the same. I understand that lots of people are experincing one way transmission on i/c calls when using the soft phone as well.
puddy
Quote from: DickB
Thanks Puddy
Try this one
Line 1  Advance Settings
Proxy and Registration
Outbound Proxy:nat.plus.net:5082
save settings
puddy
mikeathome
DickB
you might also need to forward UDP ports 5060 to 5061 and 16384 to 16482 through your router to the IP address used by the PAP2. You will need to set the PAP2 to use a static IP address for this to work reliably. I've got a linksys SPA2002 which is similar to a PAP2 and this worked for me. See http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=5204&lid=7925542973B...
Regards, Mike
puddy
