Wireless adapters help please
- Wireless adapters help please
26-10-2007 12:17 PM
Config says, Media State Media Disconnected
Discription Realtek RTL8139 Family PCI Fast Ethernet
Do I now need the adapter or would it be better to use that now I have bought it.
Help please.
Re: Wireless adapters help please
26-10-2007 2:03 PM
The RTL8139 is your Ethernet connection (wired) either on your motherboard or you have a PCI network card installed.
26-10-2007 2:05 PM
[Edit - Peter got in while I was posting ]
26-10-2007 2:43 PM
Quote from: Teds31 I have "Realtek RTL8139 Family PCI Fast Ethernet" on my computer.
Help please.
That is definitely your wired connection. It says "Media Disconnected" because there is no ethernet wire connected. Depending upon your operating system, you will need to follow some kind of installation procedure for your USB wireless "G+USB" adaptor [it (or something similar) is required for wireless].
This will give you a wired + a wireless network capable PC.
Follow the setup instructions...
26-10-2007 7:28 PM
26-10-2007 7:40 PM
Quote from: Teds31 I thought I would put my wireless router next to the main BT incoming socket and use the wireless connection to get better speeds.
That's usually the best arrangement and as far as ethernet cabling or wireless, there is nothing to be gained at current broadband speeds.
26-10-2007 8:22 PM
05-12-2007 6:03 PM
My line stats show
local line atten 41.5
local SNR 15
Does anyone think I might reach higher speeds than at present as my profile as been constant at 3770 for a long time.
05-12-2007 6:19 PM
Make sure you get a 54M capable wireless router (ie not some old second-hand stuff).
10-12-2007 11:11 PM
