Openreach New FTTP Map updated
goldenfibre
Seasoned Pro
Fixes: 12
Guys what do you think of the new map updated?
People visiting our online Ultrafast Full Fibre build map can now see the breadth and depth of our build represented by a simple three colour code:
Green - We’ve built to, or will be building to, the majority of this area
Blue – We’ve built to many parts of this area
Light grey – We’ve built to some parts of this area
https://api.superfastmaps.co.uk/fibrecities/4.0/
4 REPLIES 4
HPsauce
Aspiring Champion
Fixes: 5
Re: Openreach New FTTP Map updated
@goldenfibre asked "Guys what do you think of the new map updated?"
Hmm, not sure, extremely slow to load (Windows 11 Edge, fast dual-processor workstation, 60Mbps broadband).
Map is wrong for our exchange when you zoom in, showing it and all around as Green (V3 map was correct).
Entering full postcode DOES identify the exchange and say, correctly, "We're planning to build...." as we're on the "just released" build list at last.
So, some work to do I'd say.
Fixes: 1,495
Moderators Note
This topic has been moved from Everything Else to Tech Help
Fixes: 1,495
Painfully slow on macOS (high spec M1) with Arc, almost gave up.
Less informative than https://bidb.uk/
goldenfibre
Seasoned Pro
Fixes: 12
I always use this site https://bidb.uk/ much better one
