Open WRT Router
Fixes: 66
Open WRT Router
Here's one for those who like such things. Open WRT in it's own box.
https://www.aliexpress.com/item/1005007795779282.html
£ 84.44 including postage.
5 REPLIES 5
Fixes: 466
Re: Open WRT Router
@bmc Interesting...
I've been looking for something with more cpu 'oompf' than my Tplink ER605 running Openwrt. Its fine on my FF900 with H/W flow offloading but that precludes the use of QoS.
That box would be a slight increase from my dual core 800mhz to a dual core 1.3ghz  but I've been watching the price of the GL.iNET MT-6000 which is a quad core 2.0ghz router that will accept native Openwrt OOTB ( https://openwrt.org/toh/gl.inet/gl-mt6000 ).
https://www.amazon.co.uk/GL-iNet-GL-MT6000-Multi-Gig-Connectivity-WireGuard/dp/B0CP7S3117
paul_blitz
Re: Open WRT Router
Whilst I like the idea, I do have to ask if you are worried at all about "they have installed a custom version of OpenWRT that sends logs back to (a) China; or (b) US" (not sure which would be worse!!!)
Or are you able to upgrade it it to a trusted version?
mystreet1
Re: Open WRT Router
The first link that @MisterW posted is to the Openwrt site which details how to install a clean/fresh installation of Openwrt removing the custom version
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
Fixes: 466
Re: Open WRT Router
@paul_blitz if you wish you can just re-install from the official Openwrt site https://openwrt.org/
archerry
Re: Open WRT Router
That is a nifty bit of kit, especially for the price.
Pity I cannot justify getting one, as what I have is working nicely and I have a backup.
