ONT to switch to router
eludlow123
Moving house soon and installing a comms cabinet out of sight. The ONT is in another location but I’m thinking a single cat 6 run from the ONT to managed switch with the port tagged to VLAN x. Then at the other end of the cable another switch with a port tagged also VLAN x connecting to WAN port on the router. Then everything else on different VLANs to x.
Before I start unplugging my current setup to test, any anyone confirm this will work?
Thanks.
3 REPLIES 3
RobPN
Fixes: 15
Re: ONT to switch to router
@eludlow123 wrote:
... I’m thinking a single cat 6 run from the ONT to managed switch with the port tagged to VLAN x. Then at the other end of the cable another switch ...
@eludlow123
How many ends has your cable got?
eludlow123
Very fair point 🤣 And a reminder to me not to do too many things at once...
Explaining my thinking (hopefully) a bit bitter..
ONT to port 1 on switch i, tagged VLAN x.
Port 2 on switch i to port 1 of switch ii (in comms cabinet for instance) both on VLAN x. Port to 2 on switch ii  (still VLAN x) to router WAN port. Then all other switch ports on VLAN y, z etc...
Reason I'm not going single cable from ONT to router WAN port is I'd like some sockets at the ONT end of things.
Hopefully that makes more sense 🤦‍♂️
Fixes: 1,495
Moderators Note
This topic has been moved from Full Fibre to Tech Help
