British ring tone when using Fanvil GA11 or GA10 ATA
wintrip
I couldn't find any information on how to set up a British ring tone on the Fanvil GA11 ATA, so having worked it out, thought I would post it here for the benefit of others in a similar position.
The ring type (under Phone Settings, Media Settings, Ring Type Settings) for a British ring tone should be set to 400/200,400/2000
I am currently with Plusnet , and full fibre is about to be made available in my area. Whether or not I stay with Plusnet I am planning to move to VOIP for my landline. I have purchased a Fanvil GA11 to play with in advance, as I already have a Sipgate account (originally Sipgate Lite) for a business number that I no longer use (and an ageing Cisco ATA that still works, but I would prefer to replace for longer-term use) and costs me nothing. When I move to full fibre, I intend to port my landline number to A&A and feed the output into my existing telephone wiring using voice reinjection. I want to have al least one corded phone for two reasons (i) I prefer the shape of a corded handset and (ii) the corded phone will still work in the event of a power cut (I will have battery backup for my ONT, router and ATA).
I would recommend the GA11 rather than the GA10 as it has the BT socket. If you use the GA10 you will also need an RJ11 adapter with ring capacitor.
Moderator's note:
Post released from the automatic Spam Filter.
5 REPLIES 5
Fixes: 583
Re: British ring tone when using Fanvil GA11 or GA10 ATA
@wintrip useful information. Thanks for posting.
Not used one myself, but the GA11 looks better value than the Grandstream HTxxx options.
wintrip
Decided on the Fanvil GA11 for several reasons:
(1) Cheaper than the Grandstream (bought mine from VSIP https://www.vsip.co.uk/product/fanvil-ga11-ata-1-fxs-port-bt-socket-built)
(2) Has BT socket.
(3) Much smaller than Grandstream.
(4) Can be wall mounted.
Fixes: 583
@wintrip just looked at the manual for the GA11, it seems to have a call blocking facility (blacklist) , have you used it ?
I ask because one of the providers ( A & A ) often recommended doesnt currently support call blocking.
wintrip
I hadn't used it, but your message prompted me to give it a go.
Yes, there is a facility for blocking numbers under Call List, Restricted Incoming Calls.
However, when I blocked a number I tried calling from, instead of ringing, it went straight to voicemail. To block the number completely I had to make a change in Sipgate to turn off the setting to divert to voicemail if busy.
Fixes: 583
Not ideal, but better than nothing!.
