New laptop keys
penfold
Fixes: 5
New laptop keys
Does anyone know where to get new keys for a laptop in the UK. They are those separate keys with a hinge mechanism and 3 will not stay on. Fix appears quite simple but I'm struggling with finding a supplier in the UK.
The laptop is an hp pavilion 15 - eh0507sa
6 REPLIES 6
ExForce9
All Star
Fixes: 10
Re: New laptop keys
penfold
Fixes: 5
Re: New laptop keys
Thanks. Found those but the keys I need are always out of stock. All other vendors I can find are either in us or Europe. There's got to be some shops in the UK 😞
ExForce9
All Star
Fixes: 10
Re: New laptop keys
@penfold
Does your existing keyboard have-
  1. a fingerprint reader ?
  2. backlit keys or not ?
  3. silver or black keys ?
penfold
Fixes: 5
Re: New laptop keys
Has a fingerprint reader.
Standard silver no backlight.
I was going to replace the whole keyboard until I realised I would need to swap out the whole of the insides ..
I've found a couple in Europe but each key is €8 plus p and p. I'm going to see if I can fix them.
penfold
Fixes: 5
Re: New laptop keys
I've also messaged the eBay guy about stock.
ExForce9
All Star
Fixes: 10
Re: New laptop keys
If you end up replacing the entire keyboard and palm-rest, I found this in the UK -
https://ajparts.co.uk/products/for-hp-m08911-031-compatible-palmrest-uk-english-keyboard?variant=576...
