New BB installs, would you get IPV6 address?
fishtank
Just wondering if new FTTP -including upgrade to- from any provider, one would be allocated an IPV6 address. Or are there still enough IPV4 around or in providers' blocks.
10 REPLIES 10
markhawkin
Aspiring Champion
Fixes: 21
Re: New BB installs, would you get IPV6 address?
It depends....
I've not heard of anyone on Plusnet not getting an IPv4 public address, however if you go to an "altnet" it's quite often GCNAT on IPv6 and (usually) IPv6.
If either a public IPv4 or IPv6 matters to you then a bit of research is highly recommended.
Many users would be happy with what they get from any provider (Openreach based, Virgin Media or an Altnet) but if you have specific requirements it's well worth checking before entering into a contract.
Fixes: 113
@fishtank
If upgrading with PN on the OpenReach network you'll not get an IPv6 address. PN are currently trialling IPv6 addresses with a view to introducing them at a (probably much) later date.
As stated for other ISP's you'd need to check what they offer.
fishtank
thanks - and bmc
Yes, I understand where there might be a Static or Dynamic IP allocated.
There was also then what one might need to do in router setups and does it make any overall difference for the router security options?
markhawkin
Aspiring Champion
Fixes: 21
@fishtank
I did an upgrade from VDSL to "Full Fibre" (FTTP) with Plusnet and the process was very smooth.
For many purposes a public IPv4 address (as Plusnet provides) will suffice.
Plusnet on Full Fibre is still PPPoE, the only difference I saw with my router is that the Openreach ONT does the VLAN tags so the router doesn't have to.
I didn't see any requirement to change any router security options (I have a Draytek).
Fixes: 113
@fishtank
There are threads running on the IPv6Trial forum that may be worth reading to see if any of it makes any sense to you.
https://community.plus.net/t5/IPv6-Trial/bd-p/IPv6Trial
fishtank
Yes, but I took at face value the "...specific reference to the trial" Smiley
Fixes: 475
The easy answer to your qustion is: On joining Plusnet you will be given access to a pool of dynamic IPv4 addresses, So yes, there are sufficient IPv4 addresses still available.
Currently, IPv6 iaddresses are  not available from Plusnet as a standard option, neither is a fixed IPv4 addres..
fishtank
Right, though I seem to get a smaller range of IP on FTTC than my previous ADSL. Just saying!
Fixes: 577
@fishtank that's correct. Dynamic IP addresses on FTTC & FTTP are allocated from 'local' pools at the BRAS whereas on ADSL they were allocated directly by the CP.
fishtank
Ah right, cheers.
