Networking on Windows without joining the workgroup
- Re: Networking on Windows without joining the work...
24-08-2015 5:53 PM
I enabled Guest WIFI on my Billion 8800NL Router and allowed my neighbour to access it while his broadband was down
To my surprise all the shared folders and files on my networked computers (wired) and also the ones on his computers (wireless) were fully visible and accessible
How could this happen
P.S. It won't happen now as I isolated it via a convoluted and non intuitive procedure
Re: Networking on Windows without joining the workgroup
24-08-2015 5:57 PM
24-08-2015 6:31 PM
i may be wrong been a while since i set one up
24-08-2015 6:39 PM
it is hence my note about isolating it
Quote from: ReedRichards Surely the whole point of Guest WiFi is to prevent that? I presume you yourself were not connected to the guest network? If not, then it must be a Billion mess-up.
However that doesn't answer the fundamental question
Why, when using the Billion, does Windows see all the networked devices even when they are not part of the same Group
To add - if anyone is remotely interested - this is how to do it
Quote You need to create a 'Interface Group' for your 'Guest Network'
Example
1. Click on Interface Grouping
2. Click on 'Add'
3. Enter a 'Group Name' eg guest
4. Under 'Available LAN Interfaces' select your 'Guest Network' and click on the arrow pointing left, so the guest wifi network should now be added to 'Grouped LAN Interfaces'
5. Click on 'Apply'
6. Under 'Group Isolation' tick the box and click on 'Apply'
7. Click on 'LAN >> Ethernet'
8. Under 'Group Name' select your guest wifi group for this example I used 'guest'
9. Tick 'LAN Side Firewall' and click on 'Apply'
That should be it, the guest wifi network should be totally isolated.
24-08-2015 7:53 PM
Quote from: Oldjim the fundamental question
To me, that's not the fundamental question. Windows is trying to be helpful by showing you all the shared folders it can see. The fundamental question is "what purpose does a Guest network serve if it's not isolated from the Home network"?
24-08-2015 9:14 PM
24-08-2015 10:09 PM
For me it is the fundamental question given the known problems of networking Win 7 and XP
This router somehow manages to network them without problems
24-08-2015 11:48 PM
I presume you put your Home and guest on different subnets.
25-08-2015 7:37 AM
25-08-2015 11:04 AM
I don't understand your point
The machines at home are on a defined group which isn't the Windows default
The machines at my neighbours wouldn't be on a group with the same name
@ReedRichards
I agree it is most odd
One thing which is different between the TG582 and the Billion is that with the TG582 I had to allocate the XP computer a fixed IP address as often waking the Win 7 machine from sleep it wouldn't pick up the XP computer which was switched off every night and sometimes was given a different IP address.
This doesn't happen with the Billion
Basically, before I isolated the guest wifi, all the computers on the wired network could see all the computers and their shared folders/files on the guest wireless and vice versa. This was regardless of the operating systems which were a mixture of XP and Win 7
25-08-2015 11:21 AM
The router will know nothing about the windows groups (nor should it). It's role is to pass traffic based on the subnets and the masks, so unless you set specific rules, all connected devices will be able to see all other devices on the same subnet.
25-08-2015 11:58 AM
25-08-2015 12:00 PM
This was the link I was originally referred to over at Kitz forum http://www.billion.uk.com/forum/viewtopic.php?f=19&t=3556
25-08-2015 12:01 PM
28-08-2015 4:58 PM
as to the networking issue I setup my guest network with aid of billion fan quite some time ago on the 7800dx and then basically copied the setup across to the 8800axl when I was forced to replace the BT modem (that kept falling over) last week.
its a business router so your expected to know a bit about wifi setup, it didn't make sense to me that something using a totally separate ip range could interact with the all the other connected devices but apparently its a standard thing for shared devices to be on the primary network that all the other working groups are linked to (like printers) to allow for a business to minimise the number of hardware items requiring support
