Netgear R7000 Nighthawk with Fibre
czm
HI there
Please could somebody tell me if I can use a Netgear R7000 Nighthawk Router for my Plusnet Fibre connection?
If so is it easy to set up and is there anything in particular I should be doing?
11 REPLIES 11
Mustrum
Fixes: 81
Re: Netgear R7000 Nighthawk with Fibre
You will need a modem, as the R7000 is a router only.
I have a D7000 which does have a built in modem, and other than the username and password it is straightforward to set up.
czm
Do you have any recommendations on a modem to use with it?
Fixes: 480
The R7000 is only a router so you will need to add a modem of some sort. The D7000 includes the modem so is a better single box approach. If you have a Hub One at present you need to switch off the Hub One wireless then connect the Hub One to the R7000 via an Ethernet cable to one of the Hub One’s yellow LAN sockets. You then need to configure the R7000 as an Access Point. This is not difficult and the manual will explain how to set it up.
If you already have a BT modem then you can use this with the R7000. If you need to buy one I would recommend  a Huawei HG612 Model 3B. These are available for vey little money from  EBay. These used to be standard BT modem and can be unlocked if you want to monitor the performance of the link between the modem and the BT fibre cabinet.
czm
Thats great, thank you.
So I can use the current Hub One as the modem?   Just switch off the WIFI part of it?
czm
Yes I think I have an old BT modem as well.
Shall I use that or the hub one?
Fixes: 480
Yes, remember to use a yellow LAN socket, not the Red WAN one and set the R7000 as an Access Point.
Fixes: 480
Yes if it’s the Huawei version. The ECI ones will also work but they’re not as good, especially if your fibre cabinet is a Huawei one. Really the choice is yours.
czm
I seem to think/remember that the modem I have was supplied by Plusnet.  Would that be the Huawei version or not?
I will check when I get home.
Fixes: 480
I suspect that it would have been supplied back in the days when you had a visit from  Openreach during fibre installation. It could be either make, you will have  to look at the modem labels to see which you have.
czm
Ok so I have dug out my old Modem.
On thew back it has Echolife HG612 with a big 3B
The name says:  FTTC VDSL NTE
On the back it has the DSL port, LAN1 and LAN2 with a sticker over LAN2 saying "Not in Use"
Is this the right one to use as a modem?
Fixes: 480
Yes this is the one to use.
It will work fine as is but if you want to look at your line statistics then you need to unlock it. See https://kitz.co.uk/routers/hg612unlock.htm
