Netgear D7000v2 Setup
Jord9857
I followed this - https://community.plus.net/t5/Fibre-To-The-Premises-trial/Netgear-Nighthawk-D7000-V2-VDSL-Set-Up-Ins...
And also used the Netgear Genie 'autosetup' but just can't seem to get the internet to work, it provides the SSID's but no internet 'internet not available'.
I've got the DSL line going straight into the back of the Netgear D7000v2 router DSL port and the lights are glowing white, no orange lights.
I'm using the DSL email address which we was given on the bottom of the letter from Plusnet which I've put into the field for the ISP details
*******@plusdsl.net and password
https://imgur.com/a/2r4izcR
https://imgur.com/a/7I72Ocf
https://imgur.com/a/4MQwO8t
Any suggestions will be appreciated, thank you
5 REPLIES 5
Fixes: 577
Re: Netgear D7000v2 Setup
@Jord9857 those setup instructions are for FTTP, where the router is connected via its ethernet wan port. Im assuming you have FTTC since you are connecting via the DSL port. You need to set the WAN preference either to 'auto detect' or 'must use dsl wan' https://kb.netgear.com/29325/How-to-change-D6220-D7000-s-WAN-Preference
You also need the vlan id set to 101
Jord9857
Hi
Thank you for your quick response.
I've got FTTC so yes connecting via DSL port which it is, it's also already set to 'Must use DSL WAN' in the WAN Setup > WAN Preference
Where do I set this VLAN 101? It's already set as that in the Internet Setup
Fixes: 577
@Jord9857  It wasn't clear from your original post, but that sounds like you have it setup correctly for FTTC.
This thread https://community.plus.net/t5/Tech-Help-Software-Hardware-etc/Nether-Nighthawk-D7000-Router/m-p/1308... might be worth a look, as they had problems connecting initially.
Jord9857
I managed to sort it out by completely resetting it which also updated the firmware to the latest.
So the WiFi is now working & providing internet.
However I've got 3 ethernet cables which used to go into my Plusnet router now needing to go into the Netgear one, when plugging them into the 3 LAN(not WAN port), 2 of them show a orange/red light, the other 1 shows nothing, is that right/expected?
Cheers
Fixes: 577
@Jord9857 according to the manual https://www.downloads.netgear.com/files/GDC/D7000/D7000_UM_01July2015.pdf
The LAN port LEDs should either be white for a Gigabit connection or amber for a 10/100M connection. Off is when an unpowered device is connected.  So if you are sure the cable is ok and the connected device is powered then there is a problem!. Try connecting the device to another port to see if the problem is a failed router port
