NT SUR Gold and Windows 10
jjc
Re: NT SUR Gold and Windows 10
easy way is do not run "setup" delve into the directories and you should find a standalone installer for Outlook, I would look it up but do not have a 2000 CD any more.
nanotm
why not upgrade to a newer version of office that will actually work with windows 10 ?
