DNS problem with NASA.gov?
anthonyg
I am getting a "Can't find the server" error when trying to get to the NASA site. But access through my phone, on 3G (not Plusnet) is fine, so I'm wondering if there is some DNS problem at your end?
14 REPLIES 14
Fixes: 1,495
Re: DNS problem with NASA.gov?
working fine here on a PN connection using OpenDNS
anthonyg
It's odd - I can reach any other US site. Not a cache problem because it fails on another browser that I don't normally use except for testing.
Safari tells me it can't find the site, using Plusnet DNS.
Oldjim
Resting Legend
Fixes: 63
Also failing here using Plusnet DNS
Fixes: 1,495
looks like it's *another* PN DNS issue rather than a routing issue..
ejs
Aspiring Hero
Fixes: 25
[tt]dig @212.159.6.9 nasa.gov
; <<>> DiG 9.10.3-RedHat-9.10.3-1.fc23 <<>> @212.159.6.9 nasa.gov
; (1 server found)
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 13888
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 4096
;; QUESTION SECTION:
;nasa.gov. IN A
;; Query time: 694 msec
;; SERVER: 212.159.6.9#53(212.159.6.9)
;; WHEN: Fri Oct 02 21:37:36 BST 2015
;; MSG SIZE  rcvd: 37[/tt]
Also SERVFAIL responses looking up ns1.nasa.gov, ns2.nasa.gov, ns3.nasa.gov which should be 198.116.4.189, 198.116.4.185, 198.116.4.181 (unfortunately the routing to those three servers looks identical: Plusnet -> BT.net -> Level 3 -> nasa).
ejs
Aspiring Hero
Fixes: 25
It's working now.
Oldjim
Resting Legend
Fixes: 63
Just tried to get here and failed http://www.giss.nasa.gov/tools/panoply/
ejs
Aspiring Hero
Fixes: 25
I think the whole nasa.gov domain is broken (SERVFAIL responses) on Plusnet again.
$ dig +trace nasa.gov
; <<>> DiG 9.10.3-RedHat-9.10.3-1.fc23 <<>> +trace nasa.gov
. 513205 IN NS h.root-servers.net.
. 513205 IN NS b.root-servers.net.
. 513205 IN NS l.root-servers.net.
. 513205 IN NS k.root-servers.net.
. 513205 IN NS e.root-servers.net.
. 513205 IN NS j.root-servers.net.
. 513205 IN NS f.root-servers.net.
. 513205 IN NS i.root-servers.net.
. 513205 IN NS c.root-servers.net.
. 513205 IN NS g.root-servers.net.
. 513205 IN NS a.root-servers.net.
. 513205 IN NS d.root-servers.net.
. 513205 IN NS m.root-servers.net.
;; Received 397 bytes from 127.0.0.1#53(127.0.0.1) in 113 ms
gov. 172800 IN NS b.gov-servers.net.
gov. 172800 IN NS a.gov-servers.net.
;; Received 387 bytes from 192.112.36.4#53(g.root-servers.net) in 116 ms
nasa.gov. 86400 IN NS ns1.nasa.gov.
nasa.gov. 86400 IN NS ns2.nasa.gov.
nasa.gov. 86400 IN NS ns3.nasa.gov.
couldn't get address for 'ns1.nasa.gov': not found
couldn't get address for 'ns2.nasa.gov': not found
couldn't get address for 'ns3.nasa.gov': not found
dig: couldn't get address for 'ns1.nasa.gov': no more
I was wondering a little how it's supposed to work. I want to know the IP address for nasa.gov, so I find out the nameservers I need to ask are ns{1,2,3}.nasa.gov, but that doesn't help if I can't find the IP address for ns1.nasa.gov. How do I find the IP address for ns1.nasa.gov? I'd have to ask ns1.nasa.gov, there seems to be a sort of circular dependency.
spraxyt
Resting Legend
Fixes: 75
Whether one gets a lookup answer or not seems very intermittent with checks a few seconds apart giving both IPv6 and IPv4 addresses, just the IPv6 or IPv4 address or complete failure.
C:\>nslookup ns1.nasa.gov
Server:  dsldevice.lan
Address:  fe80::9e97:26ff:fe94:acb8
*** dsldevice.lan can't find ns1.nasa.gov: Server failed
Non-authoritative answer:
Address:  198.116.4.189
Address:  2001:4d0:8300:401::189
Addresses:  2001:4d0:8300:401::189
         198.116.4.189,
David
ejs
Aspiring Hero
Fixes: 25
There doesn't seem to be any problem getting the necessary details from a.gov-servers.net and b.gov-servers.net
dig @a.gov-servers.net nasa.gov
; <<>> DiG 9.10.3-RedHat-9.10.3-1.fc23 <<>> @a.gov-servers.net nasa.gov
; (2 servers found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 51445
;; flags: qr rd; QUERY: 1, ANSWER: 0, AUTHORITY: 3, ADDITIONAL: 7
;; WARNING: recursion requested but not available
; EDNS: version: 0, flags:; udp: 1472
;nasa.gov. IN A
;; AUTHORITY SECTION:
;; ADDITIONAL SECTION:
ns1.nasa.gov. 86400 IN A 198.116.4.189
ns2.nasa.gov. 86400 IN A 198.116.4.185
ns3.nasa.gov. 86400 IN A 198.116.4.181
ns1.nasa.gov. 86400 IN AAAA 2001:4d0:8300:401::189
ns2.nasa.gov. 86400 IN AAAA 2001:4d0:2300:401::185
ns3.nasa.gov. 86400 IN AAAA 2001:4d0:6300:401::181
;; Query time: 84 msec
;; SERVER: 69.36.157.30#53(69.36.157.30)
;; WHEN: Sun Oct 04 19:28:23 BST 2015
;; MSG SIZE  rcvd: 223
And it appears to have started completely working again for me. I think the BNG gateways may have slightly better Plusnet DNS performance.
Oldjim
Resting Legend
Fixes: 63
Now getting the same problem with http://wordpress.org/ except it seems to be a routing problem not a DNS problem - switched to Google DNS and still doesn't wok
Tracing route to wordpress.org [66.155.40.249]
over a maximum of 30 hops:
 1    <1 ms     1 ms     1 ms  home.gateway.home.gateway [192.168.1.254]
 2    13 ms    14 ms    14 ms  205.core.plus.net [195.166.130.205]
 3    14 ms    14 ms    14 ms  irb.12.ptw-cr01.plus.net [84.93.249.33]
 4    14 ms    15 ms    14 ms  195.99.126.138
 5    15 ms    15 ms    15 ms  core3-te0-0-0-15.faraday.ukcore.bt.net [213.121.193.164]
 6    15 ms    14 ms    15 ms  peer2-et-8-3-0.faraday.ukcore.bt.net [62.6.201.169]
 7    15 ms    15 ms    15 ms  213.137.183.38
 8    21 ms    22 ms    21 ms  t2c3-xe-1-0-1-0.nl-ams2.eu.bt.net [166.49.208.218]
 9     *        *        *     Request timed out.
10     *        *        *     Request timed out.
11     *        *        *     Request timed out.
12
ejs
Aspiring Hero
Fixes: 25
I'm not sure what the issue with wordpress.org is, I got timeouts waiting to load the page, then eventually got it to load, and now get a load of dns lookups for wordpress.org quickly failing with SERVFAIL responses.
Before the SERVFAILs started, the traceroute was:
# traceroute -q 1 -N 1 -T -p 80 wordpress.org
traceroute to wordpress.org (66.155.40.249), 30 hops max, 52 byte packets
1  gateway (192.168.0.1)  7.921 ms
2  lo0.14.central14.pcl-bng01.plus.net (195.166.130.142)  9.533 ms
3  irb.14.pcl-cr01.plus.net (84.93.249.145)  11.775 ms
4  195.99.126.98 (195.99.126.98)  13.291 ms
5  core4-te-0-12-0-19.faraday.ukcore.bt.net (109.159.249.21)  12.426 ms
6  peer2-et-10-3-0.faraday.ukcore.bt.net (62.6.201.171)  11.774 ms
7  213.137.183.32 (213.137.183.32)  22.336 ms
8  t2c3-xe-1-0-0-0.nl-ams2.eu.bt.net (166.49.208.216)  17.697 ms
9  *
10  *
11  *
12  *
13  *
14  66.155.40.249 (66.155.40.249)  558.618 ms
ejs
Aspiring Hero
Fixes: 25
Seems to be working now, perhaps it was just a temporary issue when the routing was changing, since it's now:
[tt]traceroute to wordpress.org (66.155.40.249), 30 hops max, 52 byte packets
1  gateway (192.168.0.1)  1.359 ms
2  lo0.14.central14.pcl-bng01.plus.net (195.166.130.142)  11.899 ms
3  irb.14.pcl-cr01.plus.net (84.93.249.145)  12.168 ms
4  ae1.ptw-cr01.plus.net (195.166.129.0)  11.653 ms
5  ae1.ptw-cr01.plus.net (195.166.129.0)  12.725 ms
6  10ge.xe-0-0-0.linxb.ldn-teleh-dis-1.peer1.net (195.66.224.156)  11.576 ms
7  *
8  *
9  *
10  *
11  *
12  wordpress.org (66.155.40.249)  176.205 ms[/tt]
