My site says " Not Secure"
pixgunnill
Help please!
Since the last upgrades with Safari and MacOS, my two websites hosted by PlusNet are showing " Not Secure ". How do I correct or change this please?
Thx
8 REPLIES 8
Marksfish
Seasoned Pro
Fixes: 4
Re: My site says " Not Secure"
Do your sites address with http or https? If you don't have SSL, or PN don't automatically provide SSL, it is a thing that Google had done, marking sites without https as untrusted. Other browsers will probably have followed suit.
pixgunnill
My sites  use http. Is there away around this?
Thx for your reply
Mike
Fixes: 1,484
only by buying and installing an ssl certificate, which I'm not sure you have the access to do on PN websites.
but it doesn't actually matter if you're not capturing data and it's only used for browsing.
pixgunnill
I use Sandvox and then Plusnet for hosting. I don't deal with money for example or transfers. It's just the annoying message I want to get rid off.
Mike
Marksfish
Seasoned Pro
Fixes: 4
Depends if ranking in search engines is important to you, as non https sites are being penalised: https://www.secjuice.com/http-vs-https/
Fixes: 1,484
But then if I was bothered about that I wouldn't use an ISP to host my website either..
Marksfish
Seasoned Pro
Fixes: 4
But some people do. Not everyone knows the ins and outs of hosting. It may be a niche site with not many hits, but the publisher may still want it to show up somewhere. The search engines used to be full of free providers, not so much now, probably due to this change.
Fixes: 1,484
There is a way - but not sure if it's palatable https://www.plus.net/help/broadband/about-your-plusnet-webspace/
so https://homepages.plus.net/<yourusername>  would get rid of the not secure message
