My overnight use is very high
FIXED- Subscribe to RSS Feed
- My overnight use is very high
- « Previous
- Next »
Re: My overnight use is very high
05-01-2018 5:48 PM
Yes that sounds best, cheers
06-01-2018 10:51 AM
@Fenster wrote:
One last question, can Plusnet disable my midnight to 8am use of internet?
Whilst turning WiFi off at night may hide (I'm still very suspicioue that your powerline units are the source of the leak) most of the evidence that some-one else has access to your network, this does not solve this issue. My advice is to find the source of the leak and stop it by using improved security.
06-01-2018 10:59 AM
Yes I will look for an app to control security of the powerline, Windows has it but I have Ubuntu Linux, will see what there is, I would think there must be something. Cheers Baldrick.
- « Previous
- Next »
