Windows fertilizes!
- Windows fertilizes!
Windows fertilizes!
02-01-2018 5:29 PM
I could have titled the thread differently, but I'm a gentleman! Every evening my name is in lights!
A few weeks back I'd noticed that several files and folders had duplicates, which I had not knowingly created. Having time just now, I used a duplicate finder, and shockingly there is a plethora of duplicates upwards on exactly the same paths.
It seems that Windows has included a muck spreader in my computer, but is there another explanation?
ideas, why the dups have arisen?
Re: Windows fertilizes!
02-01-2018 5:48 PM
Have you checked whether you have many files in /tmp or /temp or similar?
02-01-2018 6:11 PM
02-01-2018 6:30 PM
Quick access and one drive sometimes add duplicate folders
i have both off
02-01-2018 7:25 PM
Files were ordinary pics and docs, and as said were together in expected locations.
02-01-2018 7:27 PM
I'll have to neuter QA and OD then! if they're such a breeding nuisance!
02-01-2018 9:29 PM - edited 02-01-2018 9:31 PM
is this what you are seeing https://answers.microsoft.com/en-us/onedrive/forum/odwork-odshare/onedrive-creating-duplicate-files/...
if that is the case this is a way to deal with it - not nice though - https://www.clonefileschecker.com/blog/remove-microsoft-onedrive-duplicate-files/
02-01-2018 10:18 PM
@Oldjim I don't think so, as vast majority look like
02-01-2018 10:23 PM
I am probably missiing something here but they are two different file names
What is creating files every month
02-01-2018 10:27 PM
No, you're not missing anything, but there are others which are perfectly identical. It's tired old eye syndrome that struck.
03-01-2018 1:21 PM
Simple check - change the name of one of the files and see if the other half of the pair changes too.
If so @Browni is right with the Symbolic Links.
03-01-2018 2:31 PM
Or more likely you get a broken symbolic link - you need to hope that you have a hard-link.
03-01-2018 2:54 PM
I altered the original one of a pair by addition of a capital letter to the main body. The "duplicate" remains unchanged. Probably a useless move but I also did a restart after the name change.
03-01-2018 3:04 PM
I thought Windows files are not case-sensitive or is that JUST DOS?
03-01-2018 3:19 PM
Its not, but Windows Server 2008+ has the option to enable this for NFS mounts.
