Motherboard Problem
- Re: Motherboard Problem
Motherboard Problem
02-08-2012 6:34 PM
02-08-2012 6:41 PM
02-08-2012 6:42 PM
The only way it could only have a 3 month warranty is if he put in a second hand or used item
02-08-2012 7:00 PM
02-08-2012 8:05 PM
At that stage with mine currently when I am expecting my second major failure, its currently 5 years old but its on its second motherboard, first died just under 3 years old and thankfully still under warranty, now 2 years later and waiting for the inevitable failure.
03-08-2012 9:13 AM
Keep them clean and they will work, smoke is the biggest killer as it coats the fans with tar.
03-08-2012 5:25 PM
03-08-2012 6:15 PM
23-08-2012 9:02 PM
It is only by a process of elimination and of testing all your hardware first that you can pinpoint the failure.
Its worth getting a psu tester, they can be had from ebay for £5 and are easy to use. If the psu is faulty then you can get a very high quality one for £30 with a 3-5 year warranty, takes 10 mins to fit and cable tie nicely, job done. Really isnt rocket science.
24-08-2012 7:44 AM
a decent PSU you should be looking about at least £50 to get some sort of reliability
24-08-2012 8:07 AM
24-08-2012 1:49 PM
Quote would love to know where i can get a high quality PSU from for £30 unless you mean CIT < or powercool
When I built my mother's PC earlier this year I bought a Coolermaster GX RS450 PSU with 5 year warranty from scan.co.uk for £30+postage. CIT are not quality. I have had powercool PSUs fail within 12 months aswell. I have always fitted Corsair PSUs in my system builds but then I probably spend alot more cash on my rigs than the average Joe who wants to do everything on the cheap and expect it to last for 10 years.
Scan are doing a Corsair CX450w psu at the moment for £35.32 inc vat. 2 year warranty. They also do a 450w Antec PSU £30.54 inc vat 2 year warranty. Aria.co.uk do a 500w 80+ certified, 3 year warranty for £35.94 inc vat.
24-08-2012 8:02 PM
28-08-2012 8:58 PM
28-08-2012 9:46 PM
