Malwarebytes Update - Not happening
- Malwarebytes Update - Not happening
03-02-2009 10:10 PM
All other internet activity is fine including accessing their website directly.
Forum Moderator and Customer
Re: Malwarebytes Update - Not happening
03-02-2009 10:15 PM
03-02-2009 10:18 PM
Is that the free version you are using.
I also see that, with the last update - I think, I now do not have any choice of servers to update from whereas, before, there was a choice of two.
04-02-2009 9:07 AM
I manually updated this morning to 1725.
I don't see an option to select update servers.
Maybe you could try reinstalling it to kick off the updates again.
04-02-2009 11:36 AM
04-02-2009 5:55 PM
I am wondering whether the previous update had required a reboot which I had forgotten to do or just a simple glitch which a reboot resolved.
Edited header to reflect problem now resolved
04-02-2009 6:03 PM
I will add that MWB responds and works in all other areas. It is happily running a scan now.
Edit: Changed header again
04-02-2009 6:09 PM
mbam.exe /parameter
(where parameter is one of the following)
/runupdate: allows you to update the program without displaying result dialogs.
04-02-2009 6:25 PM
After reading the above I decided to try the /updateshowdialog parameter after closing down MWB.
Would you believe it - it updated fine while showing the update window. I now have database 1727.
Subsequent attempts using the usual interface gives me the expected 'You have the latest database version'.
Coincidence after using the /updateshowdialog parameter or did it fix something?
I'll try another update later and report what happens.
04-02-2009 6:48 PM
04-02-2009 6:53 PM
Just did another update attempt and now have database 1728.
I'll not mark this as resolved again just yet, though
04-02-2009 7:03 PM
OK so now you are ahead of me on updates!
04-02-2009 7:13 PM
Just updated to 1728.
If you are having trouble resolving the domain might be worth flushing your DNS resolver cache (I turn the darn DNS client service off anyway)
04-02-2009 7:22 PM
04-02-2009 7:27 PM
Truth is cant keep away when I'm finished for the day
Think I spend longer on here than any other forum I'm a member of.
