My Domain website
katie
My Domain website
Hi - I'm going crazy here as I've been trying for over a week to access my calendar on my Domain site. My main site is access by my plusnet name followed by plus.com/index.html. My Domain site is located at htdocs/Domain1. My calendar for the domain site was created using web Calendar Pad programme. I know that is is in my Domain1 folder as I have checked using both my Dreamweaver and CoreFTP programmes to check that it's there.
My problem is that I just don't know how to access the calendar -i.e. which URL to use. I am sure that I used to access it from http://brandonparish.org.uk/calendar/Calendar.html but this just doesn't work. I am lost. Can anyone give me any suggestions. The Calendar pad helpguy is trying to help me also but without much success so far. Thanks for any suggestions.
Katie Smiley
PS My Domain name is a free one from Plusnet which has worked no problem until the last week.
Fixes: 50
Re: My Domain website
Calendar.html appears to be a blank page as does february2009.html.
Customer and Forum Moderator.
Fixes: 57
But this works
http://brandonparish.org.uk/calendar/January2009.html
so it would appear that the redirect from calendar.html is trying to go to February2009.html which isn't there
Fixes: 117
Hi Katie,
Something doesn't seem to have generated the February page correctly
Redirects you to http://brandonparish.org.uk/calendar/February2009.html which is an empty file, whereas April has a generated file http://brandonparish.org.uk/calendar/April2009.html
Clicking the links in April takes you to February's events though.
never used CalendarPad, but can you try and generate February again?
EDIT: typing too slowly...
Will Moderate For Thanks
katie
Right Guys - Thank You so much for your help. I re-uploaded the February file and now it works.  Cheesy
The programme automatically instructs the calendar to open at the current month and because the February file hadn't been uploaded for some reason, I thought the whole thing hadn't worked. I am so grateful to you all for pointing out the obvious. Hopefully, I will get my calendar updated again and all will be well. Cheers - you're heroes.
Katie  Smiley
Fixes: 117
Glad we could help and that it is sorted  Smiley
katie
I just hope Plusnet will forgive me for my excessive uploading of files over the last week. I must have uploaded these files 30-40 times  Embarrassed
Katie Smiley
