Looking to upgrade Router/Modem
Rikjonno
Hi I am looking at replacing my current Tplink router with a new model but the newer ones all seem to be standalone routers and do not have a modem built in. Am I correct in thinking I will need a modem similar to the BT Openreach ones that will then plug into my new router?
2 REPLIES 2
Fixes: 480
Re: Looking to upgrade Router/Modem
@Rikjonno
Depends on your service. You need a modem for ADSL or FTTC services. FTTP connects directly to the router.
The Plusnet Hub 2 can be set to bridge mode, which turns it into a modem.
@Rikjonno
If you are either ADSL or FTTC it maybe be possible to use your current TP-Link device as a modem or use the new router as a wireless access point for the current router, what ever your decision you will need extra space for the two devices.
As suggested a Hub two can be configured as a modem and works well in that mode.
Be interested on why you have a need to update your current router.
Dan.
