Looking to buy new PC. Anyone used Cyberpower PC UK
- Looking to buy new PC. Anyone used Cyberpower PC U...
- « Previous
- 1
- 2
- Next »
Re: Looking to buy new PC. Anyone used Cyberpower PC UK
26-03-2008 2:39 PM
The OP is looking for a gaming machine, so I am not sure that the "Integrated graphics" will suit.
26-03-2008 3:25 PM
Also only 512mb ram...............might be struggling a bit ! ! !
It does say it is "re-furbished"...... and "office ready"...... can`t remember if it had a monitor/screen with it ! !
26-03-2008 3:30 PM
You could look at PowerC
A wide range of configurations available at competitive prices - I've successfully used them in the past for several projects. Speedy delivery too - usually 2 - 3 days!
Maurice
Maurice
27-03-2008 12:43 PM
I think I will go with Cyberpower PC UK. They seem to offer a wide range of systems that can be fully customized. The systems are also powerful enough to keep me going for the next couple of years. Hopefully
Thanks for the help... will post back soon on how I get on
27-03-2008 1:40 PM
Before you go there, have you checked out NOVATECH? I just received their latest catalogue through the post..... There are some really good gaming machines in there....from basic tower systems, through laptops, and peripherals,.... 63 pages and in colour..... each machine, including laptops, is given a full specifcation list, so you can see exactly what you get for your money....
I think it is well worth registering with them, (for free) to receive the catalogue and keep up to date with the latest offerings.....http://www.novatech.co.uk Three big warehouses.... Portsmouth (H.O.) Bristol and Reading....
oh by the way..... I am in no way connected to Novatech.....
- « Previous
- 1
- 2
- Next »
