netgear dg834 router
craig_p
AngryHi all
I have a netgear dg834 router with 3 pcs hard wired to it and also an x box console connected .  I was wondering how to restrict the time the x box is allowed to be connected to the internet through the router without impacting the other units connected to it so i can reduce the time my son seems to think is ok to spend on x box live. I can't find anything in the router control panel but i'm sure it has something there.  Any help or advice would be greatfully recieved.
Craig P
Njal
Re: netgear dg834 router
I haven't got one of these so I may be talking rubbish.
See the manual at:
http://kbserver.netgear.com/pdf/dg834g_dg834gb_ref_manual_03Jun05.pdf
Configure MAC address of the machine in question as reserved IP address as per page 7-6.
Configure Outbound Service restrictions as page 5-9 for the machine you wish to restrict from the Internet. You can also create those restrictions for certain time periods using instructions starting on page 5-14.
http://forums.techguy.org/networking/668346-setting-up-netgear-dg834g-router.html
Regards,
Neil
It looks good to me. I have not used the scheduler, but have used the firewall rules to block an IP address from accessing the internet.
craig_p
hi
Thanks for info.
ill try that idea and get back about it.
If there is anything else please let me know
thanks C.P.
